Question about Microwave Ovens
My microwave just stop running while trying to re heat . how im going to fix it. is their any reset button
  • 1,557 Answers
In most cases the reason for microwaves shutting down without warning is the fuse. in some cases the fuse will fail at its own fault. to test the fault we would do a tollerence test on the unit. but the best way for you to test it is to replace the ceramic fuse with another of the same value. if the unit works then its a faulty fuse. if the unit blows the fuse then the unit has a fault in the power supply that needs to be repaired by a service tech.
best of luck
Posted on Aug 03, 2010
Ran the microwave empty...it shut down. Is there a reset button
You could have burned something out on unit. Check fuse or contact GE. Look in manual for trouble shooting tips.
Jun 13, 2016 | GE Spacemaker JVM1640SJ Microwave Oven
My GE jvm2070BH002 Microwave starts but stops.
Sounds like the control board. Not many parts in a microwave oven. That is the only one that generally goes intermt
Feb 23, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Feb 14, 2010 | Sharp R-1480 Microwave Oven
Model R-1460, when I shut the door it runs but doesn't heat up. What needs to be done to fix it?
Do you mean that when you close the door, the fan comes on? If so, it sounds like a bad door switch. Probably the secondary interlock switch.
This failure is caused by opening the door when the unit is in cook mode. On ALL microwaves, not just one or two brands.......
Be sure to push the stop button before opening the door to add or stir... Or wait for the cook cycle to end. (This is why microwaves have a two step function on the stop/clear button. Hit stop once to stop cook mode and twice to reset timer).
You should use an ohm meter to check all 3 switches. The switch can be either stuck 'closed' or physically closed but not 'making' electrically.
Sep 13, 2009 | Sharp Microwave Ovens
Viking Professional (2006) 1100 watt Microwave runs but no heat?
Did you ever find out what was wrong? Ours is doing the exact same thing and we have no idea...
Apr 11, 2009 | Viking VMOS200 Microwave Oven
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
Microwave suddenly stop working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Apr 04, 2008 | Samsung MW1030WA Microwave Oven
Panasonic NN-S533WF Microwave
because of high voltage circuit thats happend ,please check highvoltage circuit may be short circuit or any companent burntout. check magnetron and high voltage diodes etc.
Sep 29, 2007 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
