Question about Nikon COOLPIX Cameras
It doesn't work at all. we have just replaced the battery but again nothing operates. It was giving excellent pics up to this point Nicola Peck
  • 3,866 Answers
I would assume the unit is not turning on when new battery was interduced, This would be caused by a faulty pin inside the unit up including the actual connector, your best bet here and not to renig on any solutions would be to have a local camera shop have a quick look. I have seen where the connector inside have been dislodged or otherwise even broken and its a simple fix if that is fact. You will probably pay areound $25 to fix the camera as a whole I sure would not recommend junking it.
Thanks for using fixya.com/
Please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 03, 2010
  • andynicpeck Aug 03, 2010
    Thanks - I was able to effect a temporary solution myself and get some action.
Can not take pics/video or zoom in and out on my s4250wm
When an error is reported, with an exclamation mark, it means the camera has a malfunction. You should contact a fuji dealer.
Before you do that, you could try to remove the battery, (make sure it is charged) then after a minute or so, replace the battery and again switch on the camera.
While the battery is out, you can check the contacts, both in the camera and on the battery. Also make sure the contacts on the memory card are clean and shiny.
The removing and inserting the battery, is equivalent to cold boot of a computer.
Mar 13, 2014 | Cameras
Instrument panel lights up but truck will not start or turn over
It could be a weak battery or a bad starter. I would take the battery out and go to your local parts store and have them test it for you. If the battery is good, it is likely the starter. You may be able to peck on the starter with a hammer (a few good hard blows) to get it working again.
Oct 23, 2013 | 2005 Nissan Frontier
I have a Samsung TL100 camera and it will not take a charge
If you haven't used it for the last 8 months and before it was all fine then the most common reason would be the battery. Your battery is absolutely dead but then again if you plug it to AC then it must show some sign of life. But give it a go by replacing new battery. To check get it from a friend and then test the camera on it.
If the battery replacement doesn't work then take it to an authorized dealer for inspection.
Oct 30, 2012 | Samsung TL100 Digital Camera
Hi My kodak camera will not stay turned on. when i turn on the camera it comes on for about 5 seconds max then shuts down again. I have only had the camera for around 18 months and this fault...
Hi Nicola,
Maybe the battery you have is defective. Try using a new battery and see if this helps.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 01, 2011 | Kodak EASYSHARE V1273 Digital Camera
Nicola motherboard sound driver
please tell me site of nicola motherboard sound driver in to downlad
Nov 23, 2010 | Computers & Internet
Motherboard is active but nothing appears on monitor
The problem is with your memory installed try inserting other RAM on your computer or if you have two memory installed try removing the other one and see if it works.
Jul 15, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open,...
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open, but no image is available just a black screen. When I I try to take pic is showed very low light but doen't show image of pic taken when I check. Please advise. This a brand new camera and was taken excellent pic as of this friday. Groove_us@yahoo.com Mr.Tracy Johnson
Apr 26, 2009 | Samsung i85 Digital Camera
Excel work sheets delete,pls how is it restore
Easiest way would be to use the Undo function to work your way back to the point prior to deleting the worksheets. If you can't back up through the list that far, you could close the file WITHOUT SAVING IT, then reopen the original file again. If you have already saved the document after deleting the worksheets, you will have to restore it from a backup (you do perform backups, right?) and continue working fro there.
Apr 15, 2009 | Microsoft Computers & Internet
Motherboard problem
Most likely the contact point of your battery pins are not snug enough. If under warranty, then replace the battery, else give it to a technician to do this clean-up operation. Try another battery too to crosscheck!.........sodeep
Mar 10, 2009 | Toshiba Satellite A100-S8111TD Notebook
S2 suddenly draining batteries rapidly
I have the same exact problem. I just now read a possible solution: try opening the battery compartment door and then closing it again to "trick" the camera into thinking it just got new batteries. There is definitely something wrong with the way the camera senses dead batteries.
Jul 28, 2007 | Canon PowerShot S2 IS Digital Camera
Cameras Logo
24 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
