Question about Emerson Pool & Spa
I'm replacing the motor on a Hayward Super Pump (1 HP) and forgot to tag the wires going to the pump motor. I know where the green wire goes (to ground), but I'm not sure about the two (red and black) hot leads. The replacement Emerson motor has posts marked L1 and L2. Does it matter which hot wire (red or black) goes to either L1 or L2? If so, how do I identify which wire goes to which post?
  • cucaracha Aug 04, 2010
    Thanks. Everything is up and running again.
  • 4,472 Answers
This link should help you clear it up. The hot or neutral doesn't matter as long as it's not going to the same place:
http://www.poolspaforum.com/forum/index.php?showtopic=12020
Thank you and good luck,
Lee
Posted on Aug 03, 2010
  • 1 more comment
  • cucaracha Aug 03, 2010
    The link seems to show a 115V setup with a hot and neutral wire. Mine is a 230V with two hot wires. Does it still not matter which wire goes to which post?
  • Lee A.
    Lee A. Aug 03, 2010
    red will go to the L1 terminal and black will go to the L2 terminal
    Thanks,
    Lee
  • Lee A.
    Lee A. Aug 04, 2010
    That is very good to hear you are very welcome. Thanks for using FixYa and enjoy!
Wiring motor for Hayward pump but it's running counterclockwise...is this right?
no is not right if you have replaced the motor on the label can tell you what wires to chnage to meke it run in the right diretion
Sep 18, 2013 | Hayward 1 12 Hp Super Swimming Pool Pump...
On the haywood superpump model c48l2n134b1 i have 2 wires to wire on L1an L2 witch wire goes were
Either wire can go to either line as long as it is only one line lead to each post. Rotation is fixed and unlike a three-phase motor, reversing the two wires does NOT reverse the motor rotation.
John
Dec 07, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
Need to know which wire goes on the L1 terminal on a Hayward Super Pump 1 hp
The black wire would go on the L1 terminal..that is the "hot" wire ...
heatman101
Aug 04, 2010 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
New 1.5 hp super pump hayward, blows circuit when turned on...
Recheck your wire connection on the motor. You likely put both your line wires on the same terminal. If not, try finding a local warranty center for a repair or replacement... http://www.haywardnet.com/locator/
Jun 11, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Irrigation sprinkler pump, flotec, 230VAC wiring
green to srcew on the motor. this is ground.,
Black on T1
Red on T2
If the rotation is going the wrong way, simply switch the black to T2
Red to T1.
Check this before you couple it to the pump..
Jun 01, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Pool pump motor wiring issue
IF THE SCREW ABOVE IS IN THE METAL MOTOR HOUSING IT IS MOST LIKELY THE GROUND. GREEN WIRES ARE ASSOCIATED WITH GROUND IN ALL ELECTRICAL APPLICATIONS. YOU SHOULD BE SAFE IN HOOKING THE GREEN TO THE SCREW. HOPE THIS HELPS, JODY
Apr 11, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Changing motor hayward 1.5 HP
Super pumps are very easy. If it is a northstar it is more difficult. Super pump. You will need 1 motor, 1 pump seal, 1 diffuser gasket, 1 housing gasket. turn off breaker, disconnect wires -noting whether it is 110 or 220 volts- , unscrew four bolts on back of pump housing (shaft side of motor), pull out motor with rear housing and diffuser (sometimes diffuser sticks inside), on wire side of motor hold shaft with wrench (flathead in some cases, but it is harder), unscrew impeller counter clockwise (like normal screw - you will nee a big pair of channel locks or a strap wrench), there are two pieces of the back housing and once the impailer is off you can remove the half that is closest to the end of the shaft to reveal four more screws, unscrew those four screws. screw back part of rear housing onto new motor. Install new pump seal to front part of rear housing and impeller, slide on front part of rear housing and then screw on impeller while holding shaft on wire side with wrench (only hand tight), replace housing gasket, replace diffuser gasket, slide into front housing and screw in four bolts. If electrical was 110 you will need to move the jumper on the wire end..if it was 220 then just hook kup wires...doesnt matter which is which as long as green or bare goes to the ground screw.
Mar 14, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Pool & Spa Logo
91 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Mike Squire
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
