Question about Kodak i1220 Pass-Through Scanner
Pls my scanner i1420 does not come ready, its only show red light
2 Suggested Answers
  • 29 Answers
SOURCE: Good afternoon. I need help. We have a KODAK i1420
If the software driver is loaded (it must be otherwise you will get e red light ) check the Image guides (the plastic window strips) check the whit reference on the underside of the guides is in place and in good condition
Posted on Oct 24, 2013
Operation error when scanning
Ensure you have the most up-to-date drivers for your i1420: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Departmental/i1420_Scanner/Support/Drivers_And_Downloads/i1400_Series_Scanner_Drivers/index.htm Looks like v3.09 is the most recent. If you are unsure of your version, download and install v3.09, if your drivers are out of date, the install will update your drivers. Test the scanner using the Scan Validation Tool (SVT). This program should be located in the Kodak folder in your start menu. SVT will test the scanner's functionality at a basic level alleviating all third party software variables. Please consult your owner's manual if you are unsure how to initiate a scan in SVT. If the 1420 scans perfectly then you need to contact IRIS for support: http://www.irislink.com/c2-2365-189/IRISPowerscan---High-Speed-Scanning-Software.aspx
Mar 24, 2014 | Kodak i1420 Pass-Through Scanner
Images have a streak of color in the middle
The problem you describe sounds like moire.
Try scanning the image at different resolutions until the effect disappears.
Dec 12, 2013 | Kodak i1420 Pass-Through Scanner
Oct 24, 2013 | Kodak i1420 Pass-Through Scanner
My printer canon 4412 not work the display showing on main switch e202-0002
hi my printer canon mf 4412 printer is not working it is showing error batten red light showing , display is not showing pls solve problem pls it is urgent
Apr 05, 2011 | Office Equipment & Supplies
Once i powered the avision 220 on, The moniter shows E and 7
When you first turn the scanner on, the READY light will blink, indicating that the diagnostics are in progress. Observe
the front panel Error LED (Red) closely. In a short time, the Error LED indicates the results of the offline diagnostics as
explained below.
Ready LED(Green) is off and Error LED(Red) indicates 7, the error indication is"Face down light check failure".
Followings are the solution for the above problem:
1. CCFL is on? Yes. CCD error, Optical assembly is to be replaced.
2. CCFL is on? No. Inverter error. Lamp inverter circuit is to be replaced.
3. CCFL is on? Yes. Issue resolved.
4. If the CCFL is still off, then CCFL is to be replaced.
Hope the above information is helpful.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
Nov 01, 2009 | Ambir Technology Avision 220 Pass-Through...
Scanner problem
I contacted tech support at UMAX
Apr 23, 2008 | Umax Astra 2100U Flatbed Scanner
Scanner problem
Try scanning a double sided document in duplex mode. Reverse the page and scan again. Make sure contrast/rightness settings are okay. If one side output is still not okay, then it possible that the lighting has failed. Either loose contact or failure of the lamp. Some scanners have LEDs and some have a lamp.
S. Mohan
Feb 19, 2008 | Office Equipment & Supplies
Ready/Error Light
IT have just been down to look at our scanner & cleaned the sensor which is in between the rollers just where the paper flits out at the bottom - we now have a green light! So look for that sensor.
Apr 18, 2007 | Panasonic KV-S2046C Pass-Through Scanner
Kodak i1220 Pass-Through Scanner Logo
44 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
