Question about Gateway FPD2275W LCD Monitor
Horizontal/Vertical Postion of Image on LCD Monitor
Just got it back from Acer repair in Roundtop, Texas AND the image is distorted horizontally. Manual doesn't give clear instructions on how to toggle between available buttons to fix this problem as well as others.
    Problem Solver:
  • 19 Answers
The controls for focus adjustment are on the flyback transformer, (that big black thing on the left hand side (usually) of the monitor with the thick red wire that goes to the CRT.) the flyback may have 1,2,3 or even 4 knobs on it. 3 of these would be labled SCREEN (bottom knob of flyback. handles brightness)
FOCUS 1 + FOCUS 2 (focus adjustments. these are what you need to play with) and the 4th knob (some old mitsubishi workstation monitors had these) i do not know, it wasnt labled and HV adjustment was on the deflection board
Posted on Apr 26, 2008
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
In 2004 I bought a monitor Hansol 930 D model, (model no.D19BL, s/n A23490411020263) Since 2011, horizontal image began to narrow, now horizontal image H-size is 210 mm. vertical image size is ...
The horizontal deflection coil is shorted. There is no way to fix that, the entire tube would have to be replaced and that would cost as much as a new monitor.
Just buy a second-hand LCD monitor from here
http://www.diabloscomputer.ro/monitoare-second-hand-fujitsu-siemens-p19-2
Asta l-am luat eu si are o imagine excelenta.
Jul 01, 2011 | Hansol Europe 930D 19" CRT Monitor
The screen has lines and double vertical images then horizonal black lines form and no image is there - a virus?
there is no virus. the problem is the screen. you need to replace it with new screen or let if fix by a technician. they will replace the vertical and horizontal transistor. or so.
Mar 05, 2010 | Acer AL1715 17" LCD Monitor
"Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 27, 2010 | ViewSonic VX2235WM Monitor
Monitor Curcuit Problem
re-adjust the vertical and horizontal size then exit the menu
Oct 22, 2008 | AOC LM729 17" LCD Monitor
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Sep 09, 2008 | Acer AL2216WBD LCD Monitor
Horizontal lines
i suggest you change video board .
Apr 19, 2008 | Samsung SyncMaster 152N 15" LCD Monitor
Monitor display has flipped from horizontal view to vertical view. It is an ACER monitor and computer, with windows VISTA. please help!!!!
Hi Guest!
Try pressing the keys Control, Alt, down arrow. Then try the Control, Alt, up arrow. This flips the image on a lot of Nvidia cards. Good Luck.
Dec 31, 2007 | Acer AL1916W 19" LCD Monitor
Screen image display distortion
Hello.
What you are reporting is a problem in the pincushion circuit in the horizontal section of your CRT monitor. Usually this is from an electrolytic capacitor that is no longer willing to play nice with all the other components.
It is repairable, but get an estimate first. If the repair bill appears to be around $100, you would be better off to put a few more dollars with that and buy an LCD TFT monitor.
If you are quoted $25 or $30, it is probably worth having repaired. Just keep in mind that these older CRT monitors have age on their components, and once repaired, it will still be an old monitor.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
I hope this helps.
Nov 06, 2007 | Apple Multiple Scan 1705 Monitor
Gateway FPD2275W LCD Monitor Logo
109 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
