Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Problem with Sony TV; rainbow picture/convergence
I am about to replace two IC's [Sanyo STK-392-560] to correct the convergence problems. I have read that I should also replace 3 transistors. How will I know which transistors are bad?
  • Sony Master
  • 8,617 Answers
No you should check the 4.7 ohm resistors located under the heat sink fins they usually will go open
Posted on Apr 26, 2008
I need a manual for sanyo tv model ds27880
Try Googling (sanyo)(ds27880)(manual) without parens.
Jan 10, 2017 | Sanyo Televison & Video
My Sanyo tv is flashing different colours how can I stop it
Unplug from wall, and hold power button it for about a minute. Replug and turn on and see if that resets unit. If not, it needs repair.
I have a Sanyo LED tv model DP58D33. It turns on and functions perfectly for awhile, then screen goes black but still has sound.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 09, 2017 | Sanyo Televison & Video
Sony TV question. Lightning surge, no lights, no picture, fuse is good.I have the model number. looking at back of tv now, cover removed.
YOUR GONNA NEED A NEW TV ITS FRIED IT WHEN ITS STORMING YOURE SUPPOSED TO UNPLUG ALL ELECTRONICS BECAUSE OF THAT ISSUE
Jan 09, 2017 | Sony Televison & Video
I HAVE AN AKAI HD TV DVB-T32W. When I started out first time, it autoscans but found no channel. press DTV or ATV, it,says "No channel. need to rescan". But nothing happens, thanks
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jan 09, 2017 | Akai Televison & Video
Truetech 10 inch under the counter tv is stuck on channel 2. I need 3. Channel buttons on tv & remote do not change 2 to channel 3. Unplugging, Resetting hasn't worked Any ideas?
Jan 08, 2017 | Televison & Video
Sony 29 crt flat tv picture horyzantly sifted and led light five times blinking
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Jan 08, 2017 | Sony Televison & Video
Replaced convergence on toshiba 42HDX82...put back together now no picture or sound...could i have rehooked up wires wrong?
YES YOU COULLD HAVE WRONGLY HOOKED UP THE WIRES AND TANGLED THEM UP WHICH IS CAUSING THIS TO HAPPEN BECAUSE ITS CAUSING THE THE VOLTAGE THE TO ENTER AND CAUSING THIS TO HAPPEN
Nov 30, 2016 | Toshiba 42HDX82 42" Rear Projection...
Tcl tv line through screen
maybe vertical ic be came hot and make some lige unconnected in board have to go to tv tichnican
May 18, 2013 | Televison & Video
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
