Question about Logitech Webcam
Why it not showing nothing... when you insert the usb and it say waiting too connect it not connecting
    President:
  • 1,566 Answers
Please try to download the camera driver again and reinstall. You can obtain one from the website. Do a computer reboot and provide feedback if it still does not work.
Posted on Aug 03, 2010
Show error
E indicates an Error condition.
1.Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon ( ). If your printer has a network or wireless connection, ignore this step.
Figure 1: Example USB connection (your product might not look exactly the same as this example)
2.Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
NOTE:If your printer does not have a display, wait until the cartridge lights blink. If the cartridge lights do not blink within a few minutes, skip to the next step.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
5.Wait 60 seconds.
If that doesn't work you can log on to HP.com/Support and Drivers.
Find your device and search the error codes listed.
You can also download a real good Utility, HP Print and Scan Doctor.
Apr 27, 2012 | HP DeskJet F380 All-In-One Printer
How do i connect the mouse? Belkin Wireless comfort mouse F5l030-BGP I put the usb in and nothing happens
Insert your USB receiver into a USB port on your computer. If you are using a laptop, you'll usually find a USB port on the side. If you are using a desktop computer, it's likely located on the front or rear of the tower.
Wait for your computer to install the drivers. You'll see a progress balloon in the bottom-right corner of your desktop screen. After a minute or so, it should show "Success." If it does not, or if there is an error, visit the Belkin resource to download the drivers.
Turn the mouse over and push the switch to "On." The mouse should automatically communicate with the USB receiver. Test the mouse to determine if it has. If the mouse does not work, press the "Connect" button on the receiver and then press the "Connect" button on your mouse. The mouse should be functional.
Mar 22, 2011 | Computers & Internet
It will not charge
I have the exact camera, when you plug it in does the USB cable show red? If so this means the cable and the battery are connected and the red is a charging status. If you can turn on the camera while it's plugged in then its not the cord or the camera but the battery. If it just fails to charge but does power up and connect via USB i would look into a new bettery. If the USB cable does NOT respond at all when plugged into the PC by itself then the cable is bad and you need a new one. It will flash red/green/yellow if it's 100% functional. If your cable does respond but does nothing when the camera is plugged in then it may also be the cable's connections or the camera's internal port has been damaged. If you want to make sure it is the battery then plug in your cable, wait for it to cycle through the colors and connect your camera WITHOUT the battery inserted. It should do nothing, then while its connected to the cable insert the battery, If the cable turns red but will not charge then it's 95% a battery issue.
Jun 28, 2010 | Samsung SL420 Digital Camera
SHARP AR-5320 is not printing. it is connected by USB. It is showing ready and when i give print command it shows that the document is printing and there is some action with the printer but the print...
remove driver from control panel,disconnect USB restart pc insert cd ,install again ,when pc wants to connect copier,do this and wait to complete.your cassete size must be same as your print size
Mar 05, 2010 | OCE 3140 Copier
Connection problem with Canon 450D to PC.
Use a card reader to download your pictures to a folder you create on your desktop.
Oct 07, 2009 | Canon EOS 450D Digital Camera
I have inserted an SD Card (2GB) into my Alba pocket camcorder and nothing appears to be working on the camcorder. There is a small red light showing underneath the Rec and Zoom in/Out controls but apart...
Hi!
Have you inserted a new SD card? If this is already a used one, you can try to reformat it and then test with the Pocket camera again.
With the issue on the device recognition on your Windows PC, you should make sure that the correct driver is installed.
Will wait for your reply.
Aug 27, 2009 | Video Cameras
PSP USB connection- screen reads please wait
there might be somthing wrong with the hard drive or with the usb
Mar 31, 2009 | Sony PlayStation Portable (PSP) Console
Sony nwz-S515
Try adjust the USB cable and/or switch which USB port it's connected to on your computer. Also just patiently let the player sit and try not to perform any other actions on the computer. When mine did this, I opened Media Player, wiggled the USB cable and waited. Eventually it connected and worked correctly.
Sep 28, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
SA6045: Waiting on USB connection, then nothing
1. Go to
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA6045/97&scy=IN&slg=en#
2. Search for 'USB' word on the page.
3. Click on the link
4. follow the instruction
5. After step 11, connect MP3 player again to PC.
6. You will see that the MP3 player running an update. Wait until the update is done
7. Disconnect it from PC. Now you are ready to use it.
May 08, 2008 | Philips GOGEAR SA6045 MP3 Player
Connecting with PC
Make sure that the driver letter is not being "shared" with another letter. You might want to check in that "removable device " under "Manage".
May 05, 2008 | Samsung SGH-D600 Cellular Phone
Logitech Webcam Logo
32 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
