Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
IT will not put out or **** up water - Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
  • 276 Answers
Try these suggestions to get your machine working properly:
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
If these suggestions do not resolve your issue contact BISSELL Consumer Services for further assistance.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Posted on Aug 03, 2010
I have a bissell upright deep cleaner quicksteamer and it will not suck up water.
Make sure first it is putting out enough water. People often think it's not sucking up the water when it is actually only putting out a very small amount of water...enough to see but not enough to suck up. If it's putting it out and not sucking it back up you have to have a clog or a suction leak somewhere.
Jul 07, 2018 | Bissell Vacuums
The dirty water tank will not fill up
Make sure it's putting the right amount of water down. Many machines brought in to my store for repairs are putting down just a small amount but people think its not extracting any when the real problem is not putting out enough water.
If that's not the case make sure there are no clogs or suction leaks anywhere which will greatly reduce water extraction.
Mar 15, 2017 | Vacuums
F7210-900 Steam Vac. will not put out water when switch is in wash position but it will put out water when the rinse position
There are two electrical solenoids inside the hood assembly. One opens to dispense rinse water, and the other dispenses the soap and water solution. It is likely that the soap and water solenoid has failed and will require replacement. A "work around" fix for this is to mix the soap solution in the clear water tank ( 5 oz. of shampoo per gallon of water ), and shampoo that way until the solenoid can be replaced.
Mar 15, 2011 | Hoover Vacuums
I don't have instructions for the Rainbow shampooer. I'm not sure how much water to put in, or whether I put water in both reservoirs. Does anyone know?
Water only goes into the cub in the handle. The dirty water gets put into the bowl on the canister part.
Nov 28, 2009 | Rainbow Vacuums
Don't know how much water to use in Scunci Steam Cleaner
The little cup that comes with it to fill it has a line on it and says "220ml MAX". I would not recommend putting anything but water into it!
Aug 08, 2009 | Scunci 52067 Handheld Steam Vacuum
Can't get it open
had same problem. Tried pouring boiling water over cap and it seemed to loosen some so I boiled more water and put the steamer top down in a bowl in the kitchen sink and pour the boiling water in and let it sit about 5 minutes. It came loose with some effort. The grooves are the opening are metal and they had started to corrode.Once open coat with wd40.
Jan 31, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
Do you put hot water in the tank
It would depend on whether you machine preheats the water or not,and what kind of machine,Bissell,GE,etc..If your machine doesn't heat the water,then I would use hot water.Do not boil water,tap is fine.
Dec 16, 2008 | Hoover SteamVac F5914-900 SpinScrub...
IWOULD TO KNOW IF STEAM CLEANER ARE HEATED WATER
yes, they heat water to over boiling point by putting it under pressure so you only get steam. it cleans with very little water.
Jul 27, 2008 | Vacuums
Water?
There are two tanks on that machine. The lower tank is the recovery for the dirty water and the upper tank is for the clean water solution. You mix the detergent with the clean water and away you go.
Feb 08, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Lost directions to the cleaner.
Hi , check the water level and refill it .
Jan 21, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
146 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
