Question about HP Photosmart 735 Digital Camera
Memory Card What is the maximum size SD card that can be used in the 735? Thanks BIll
  • ivangrom Jul 29, 2008
    doesn t support 2 gb sd card...downgreate it in 1 gb and i can t get back...
  • Mike Johnson
    Mike Johnson May 11, 2010
    what is the make and model of the camera ???
  • 477 Answers
Your camera shows tobe able to handle a 1 gig chip I donot see any thing about a 2 gig.hope this helps
Posted on Apr 25, 2008
  • 4,102 Answers
Hi. i know a 1g will work fine in this camera i have not tried anything bigger as i never fill the 1g to worry about upgrading beyond that so i would say 1g should be more than plenty for your needs ok.
Let me know if you need further assistance
these cards can go up to 4g but never tried them in the camera cant see why they wouldnt work but i know for sure the 1g works with no problems.
Hope this answers your question.
    Guru:
  • 1,463 Answers
I insert memory card in to my touch t-mobile but not supported say format memory card what shall i do right now?
Hi Teddy.
Regarding the issue you have with the memory card & the error message showing on the phone. It could be that the memory card you're using is not compatible with the phone model that you have.
Every phone has it's own maximum size of the memory card compatible to it.
E.x. A phone could only support up to 2Gb, but your memory card size is 4Gb.
You could contact your phone manufacturer & ask the maximum size of the memory card allowed for your phone.
If your memory card is compatible with your phone, you could just proceed in formatting the memory card on your phone.
**WARNING**
Formatting the memory card will erase everything saved in it.
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 21, 2013 | Kingston Secure Digital MicroSD /...
What is the maximum size of a SD memory card that the Philips digital photo display model 9ff2 can support?
The maximum size of an SD card is 2GB, and the 9FF2 will support SD cards of that size. The 9FF2 will not support SDHC cards, which start at 4GB and go up.
Mar 29, 2012 | Cameras
My camera gets easily full though i've just taken only one or two pictures. What should i do? Please help me solve this problem. I badly need my camera now as I am documenting for my thesis. Thanks much.
Sounds like you may not have a SD memory card in your camera (or have been using a 4GB SDHC card), and your images are being saved to the camera's very limited "built-in" memory. What size SD memory card are you using. If there is none (or if you're using a 4GB SDHC), recommend purchasing a standard SD card no larger than 2GB files size for your model camera (think of it as the camera's reusable film).
Note that 4GB and higher SDHC cards will not work with your camera as it was manufactured before SDHC format came out (this also could be causing the camera to default to built-in memory). Again, the maximum SD card size that your camera can use is 2GB. These can still be purchased, and are relatively inexpensive on Amazon.
Mar 24, 2011 | Casio Exilim EX-Z750 Digital Camera
How long does it take to format the SD card? I have been waiting for this card to format for an hour. Message appears "no card" when the card is in the camcorder. Thanks,
You don't say what make or model of camera or the size of the memory card, so I am going to have to do some guessing.
My guess is that the memory card is incompatible with the camera. That would explain why the card is not recognised and why the camera cannot format it (it tries to, but hangs). Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity memory card a camera will use, as today's cards are much larger that those available when the manual for the camera was written.
There is a common problem with SD cards. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 03, 2011 | Cameras
What size memory card do I need for the 735 camera?
The 735 uses MMC and SD cards. Both types are limited to 2GB maximum. Be careful not to use SDHC cards. While they will fit into the slot, they are electronically incompatible and won't work.
Nov 06, 2010 | HP Photosmart 735 Digital Camera
Maximum SD card size for TomTom ONE XL
The XLS which is not that much different and supports 4Gb as used in mine which allows me to keep maps of the US,Canada, UK, and the whole of europe on it and swap at will. I bought a cheap generic one. I do kow that those cards that use micro sd can and do have problems so best to avoid the micro type unless your device takes those specifically
Nov 29, 2008 | Tomtom ONE GPS Receiver
Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
May 17, 2008 | Pentax Optio S5n Digital Camera
What is the maximum amount of SD/MMC memory on e330
In my opinion there is no any limitation. I am pretty sure that you can use 1GB SD Card without any problems. Only thing that can happen is that access to your data can be a little bit slower.
Sep 11, 2005 | Toshiba e330 Pocket PC
HP Photosmart 735 Digital Camera Logo
114 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
