Question about Whirlpool Dryers
I was given the dryer, and the cord unattached. I want to be sure I attach them correctly. The cord has three prongs and ther are three holes for attachment. Where should the grounding be atached?
    Scholar:
  • 32 Answers
For a 3-pronged cord, the ground (nuetral) is the middle wire on the cord and is attached to the middle terminal post. the outside wires are attached to the outside posts. It doesn't matter which wire goes to which side.
On 4-pronged cords, there is a fourth green wire that is attached the unit's case for grounding purposes. Which cord you use is dictated by what power outlet you have, 3 or 4-pronged.
If I can help anymore, please let me know.
Best, G
Posted on Aug 03, 2010
Testimonial: "Thanks very much. your response was succinct and clear."
My Gibson dryer has a three prong plug on it.I
The National Electrical Code began requiring 4-prong receptacles for 220-volt residential circuits in 2000, but it doesn't prohibit you from using your older dryer with a 3-prong cord. Instead, it allows you to change the cord so that the dryer can be plugged into a modern receptacle, and the procedure isn't very complicated. Four-prong dryer cords, or pigtails, are available at hardware and electrical supply stores, and usually cost less than $20. To make the switch, you'll need a green ground screw to attach to the dryer body so the machine can be grounded by the ground wire.
1 Unplug the dryer and move it to an accessible spot. Unscrew the plate on the back that covers the electrical terminal with a screwdriver. You'll find the cover on the back of the dryer near the bottom of the machine at the point where the cord exits.
2 Loosen the three terminal screws holding the cord. Before you remove them and take off the cord, note the colors of the screws and the wires attached to them. The screws holding the black and red wires are brass and the one holding the white wire is silver.
3 Remove the ground strap from the silver terminal. It may be a small metal plate or a length of wire connecting the terminal to the body of the dryer. You may be able to pull it out with pliers, or you may have to loosen a screw to remove it. Its function was to ground the dryer, and that function will now be served by the ground wire on the new pigtail.
4 Insert the brass terminal screws into the ring lugs attached to the red and black wires on a replacement pigtail and the silver screw into the ring lug on the white wire. Drive the screws into the same slots from which you removed them and tighten them securely with a screwdriver.
5 Drill a 1/4-inch hole in the body of the dryer within reach of the fourth wire in the pigtail, which is green. Insert a green ground screw through the ring lug on the end of that wire, drive the screw into the hole and tighten it securely.
6 Feed the cord through the notch on the terminal cover plate and screw the cover plate to the back of the dryer.
Things You Will Need
  • Screwdriver
  • Pliers
  • Drill
  • 1/4-inch drill bit
  • Ground screw
  • 4-prong pigtail
Tip
  • There usually isn't room behind the cover plate to install the ground screw. If not, it's acceptable to attach the screw to the back of the dryer outside the plate.
  • Check the grounding with a multimeter before you plug in the dryer. Set the meter to ohms, touch one lead to the dryer body and touch the other lead to the ground prong on the plug. The meter should show less than 10 ohms of resistance.
References
Sep 12, 2014 | Dryers
Fisher paykel DegX1 replacement cord istallation
Well, of all the problems, you selected an easier one!
Your four-pronged cord has two straight lugs on it.
These are "HOT".
You also have two more lugs, one is round, and one is "L" shaped.
Those two are "ground".
Here's how they attach.
Inside the rear of your machine are 3 screws/nuts in a row.
The outside 2 screws/nuts are both HOT, and it doesn't matter whether the red wire goes to the left one or the right one.
Same with the black wire.
Goes to the left or the right.
The center screw/nut is for the white ground wire.
The other wire (maybe green or maybe blue) should be attached to the side of the hole where the wire enters the dryer.
That one should be put under a screw on the side of the hole, fastened to the "case" or the body of the dryer.
Be blessed.
Mar 20, 2013 | Fisher and Paykel DEGX1 Electric Dryer
Three prong to 4 prong outlet
Yes it can be. I suggest you get a licensed electrician to handle it.
Jan 27, 2013 | Bosch Nexxt 500 Dryer
What type of power cord do i need?
An electric dryer has an opening in the back, older units use a three prong cord, there will be three posts to attach cord, newer units have four prong cords, Bought separately. there will be four posts to attach, double grounded cord.
Jan 17, 2013 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
How to hook up a ge dryer change from a THREE PRONG TO FOUR PRONG HOOK UP
Replace the old Three prong cord with a 4 prong.
White wire from 4 prong cord goes to the center terminal of the connector block. If there is a metallic strip on that terminal that goes to ground remove it from the terminal and bend it away from the terminal and down so it either touches the case or ends in thin air. Be sure it can't touch either of the outside terminals of the 3 terminal block.
Red and Black wires of cord go to outside terminals of the three terminal block. It makes no difference which one goes on which terminal but I usually attach them so the color of the cord wire matches the colors of the wires already on that terminal.
The last terminal is green and should be attached tightly to any screw of the case or any metal bracket attached to the case that it is long enough to reach as this is the ground. This lead protects you from electrocution if the dryer has an internal problem and should be tight to the case.
Sep 22, 2009 | Dryers
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Jul 23, 2009 | Dryers
Hooking up the four prong cord to the dryer
this is the rule of thumb,white always goes on the middle terminal ,the 2 outside terminal wires it does not matter which side they are on,if you can see the red and black wire on the terminal block then match them up,the green wire gets mounted to the cabinet,you should already have a green wire to the cabinet so remove the screw and put both wires there and your done,let me know how you do-mike
Oct 15, 2008 | Frigidaire FEQ332E Electric Dryer
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
