Question about Whirlpool Dishwashers
My dishwasher is not getting thesliverware clean or the cups
  • Whirlpool Master
  • 43,501 Answers
Check your heating element..
Dishwashermy dishwasher is not getting - 2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 03, 2010
Tip
How to Sanitize Your Dishwasher
Step 1 -
Get rid of any odor that may be coming from the plumbing pips your dishwasher shares with the sink. Pour a half of cup of baking soda down each sink drain. Pour cups of vinegar down each drain until all of the baking soda is washed away. After five minutes, run very, very hot water down each of the drains.
Step 2 -
Clean out your garbage disposal. Slice a lemon/lime and put the slices down your disposal drain. Run your disposal with cold water running.
Step 3 -
Pour two cups of vinegar into the dishwasher and let it sit for an hour and then let the dishwasher run through a cycle with the hottest water possible. Repeat the process is that does not clean up all of the build and film. You can use baking soda and bleach instead of vinegar - just sprinkle the baking soda in the bottom of the dishwasher tub, and pour bleach inside the tub as well.
Step 4 - Between washes, pour 1/4 cup of lemon juice into the dishwasher cup and run a short, but complete wash cycle. This will not only deodorize the dishwasher but will also help get rid of any metal build-up.
on Oct 19, 2011 | Frigidaire Dishwashers
Is there something to clean out for waste? Dishwasher is stinky
Method 2 Removing Smell with Vinegar and Baking Soda
  • Place one cup (8 oz) of distilled white vinegar in the top rack of the dishwasher. ...
  • Run the dishwasher for a full cycle. ...
  • Sprinkle a cup of baking soda over the bottom of the dishwasher. ...
  • Run an additional cycle.
3 Ways to Clean a Smelly Dishwasher - wikiHow
www.wikihow.com/Clean-a-Smelly-Dishwasher https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Dishwasher+is+stinky
Dec 02, 2016 | Dishwashers
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
We are getting a strong odor from our two compartment dishwasher, would welcome any suggestions
Get rid of any odor that may be coming from the plumbing pipes your dishwasher shares with the sink. Pour a half a cup of baking soda down each sink drain. Pour cups of vinegar down each drain until all the baking soda is washed away. After 5 minutes, run very, very hot water down each of the drains.
Clean out your garbage disposal. Slice a lemon and put the slices down your disposal drain. Run your disposal with the cold water running. You can use just the lemon or an orange rind if you don't have a whole lemon.
Pour two cups of vinegar into the dishwasher and let it sit for an hour and then let the dishwasher run through a cycle with the hottest water possible. Repeat the process if that does not help. You can use baking soda instead of vinegar - just sprinkle it in the bottom of the dishwasher.
Between washes, pour ¼ cup lemon juice into the dishwasher cup, and run a short but complete wash cycle. Is will not only deodorize the dishwasher, but will also help get rid of any metal build-up
Nov 03, 2010 | Fisher and Paykel Dishwashers
We have a 2 draw F & P dishwasher but at the end of a cycle the cups in the cup rack do not seem to be clean on the outside. We place the cups face down, the inside seems to get clean O.K. but there...
If the problem does not get fixed by increasing the rinse aid quantity setting, and assuming you do not live in a hard water area, I would recommend buying a Finish dishwasher cleaning kit (2 pieces) and run dishwasher on high temperature cycle one drawer at a time.
Sep 20, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Aug 29, 2010 | KitchenAid Dishwashers
Left over soap residue in glasses
you need to flush out the dishwasher, fill a cup with vinager and put it in the dishwasher standing up, then run the dishwasher thru a heavy duty cycle with no dishs. Then cut back on your soap, with new dishwashers and soaps you dont need much at all
Jul 08, 2009 | KitchenAid Food Grinder & Vegetable...
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
Heating Element
Filter/Drain Grate
  • filter
  • . Detergent or Detergent Cup
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    Tablet door dosn't open during cycle
    It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
    Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
    Dishwashers Logo
    35 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
