Question about Emerson Pool & Spa
Pump leaking at impeller orwear ring emerson model c55ckas-4792 moter 1081\1563
  • 15 Answers
SOURCE: I have a Hayward Northstar
wow, thats odd. If you replaced every seal/o-ring and its still leaking its gotta be 1 of 2 things
You installed the shaft seal wrong- no disrespect, just a possibility
or there is a hairline crack somewhere you are missing...
Posted on Aug 23, 2010
Testimonial: "The shaft seal ould be a possibility but I think I'm OK there. However, I did check the pump again today and there was NO LEAK. Thanks anyway"
adamh294
  • 310 Answers
SOURCE: I need to purchase a Emerson 1563 spa motor. Cat.
I have 2 of them. E-mail me
adamh@newconceptchem.com
Posted on Oct 27, 2010
adamh294
  • 310 Answers
SOURCE: my emerson spa circulation pump 1563, model
Im sure it is way too late, but i have the original replacement for this item.
Posted on Nov 01, 2010
john224
  • 1378 Answers
SOURCE: Wiring up Emerson 1081 pool pump. Using 230V. Is
Thank you for posting your question here on Fixya.com.
There is no polarity associated with the leads in an AC system. You simply have 2 hot wires and you can hook either one to either Line 1 or Line 2. Motor rotation is not dictated by the connection arrangement of these leads. Ground the motor with the grounding wire and again with the bond wire if one is present.
You can remove the riser that is positioned under the motor to allow for a 56 size stator to fit in place of the 48 size stator the original Hayward (AOSmith) motor was.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Nov 02, 2010
UglyPoolGuy
  • 46 Answers
SOURCE: where can i order the impeller (center dish cover)
The impellers for the motor depends on the actual brand of pump that the motor is actually bolted up to. Impellers are available anywhere and once you can let us know what the actual model of the pump (should be a Hayward, Jandy, or it may be an off brand) we can not only provide you with the part number, but also a location where to purchase. What is probably happening is that you are searching for the impeller for an emerson, instead of looking for the imepller for the appropriate pump.
Posted on Feb 07, 2011
Where can I find a diagram to fix a pump K55MYGRD-8367
this can be a hard pump to service. but you can remove the front pump housing and see if you can remove the impeller by hand, the back of the motor will have a screwdriver slot in the shaft to hold the rotor still while attempting to unscrew the impeller. after removing impeller you will need to remove the 4 thru bolts this will allow you access to the ceramic portion of the shaft seal assembly.
replace all needed parts and reassemble. never run pumps dry always prime the pump with water.
doing this job can save you a bunch of money and usually cost about $150 at my shop.
Jay the pool pump repair guy Longwood FL.
Jun 26, 2017 | Emerson Pool & Spa
Spa pump leak
Failed Mechanical 'Pump Shaft Seal'
Apr 13, 2014 | Emerson Pool & Spa
Electric motor runs but pump does not run, Model 05-001
It sounds like either a suction leak or an impeller problem. Remove the lid from over the pump basket and fill the pot with water. Leave the lid off and start the pump. The water should be sucked into the pump almost instantly.
If it did, you probably have a suction leak. Check out the lid o-ring.
If the water didn't move your impeller is clogged or has stripped out. The pump needs to opened to see what happened.
Jan 14, 2014 | Pool & Spa
My Emerson motor model k63cxese 4792. It is making a loud noise. I was told the capacitor might be bad. Does anyone know how to replace the capacitor? Thank you
Capacitors don't make noise. The purpose of a capacitor, is to provide a jumpstart to assist the motor to begin spinning. What makes a pool motor noisy, is bad bearings. At one point or another is possible that your mechanical pump shaft seal had failed, and allow the water to enter the electric motor, and wash away the lubrication in the front bearing.
either replace the bearings or the motor.
Dec 05, 2013 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Moter leaks when filtering
Is it leaking at the motor shaft or where the filter gasket and pump housing bolt together? If between the two housings,then it may just be a matter of tightening the screws that hold them together. If it is leaking around the shaft, you will need to replace the mechanical shaft seal.
To replace the seal you will need to remove the housings and then unscrew the impeller from the shaft. There is a slotted end on the other end of the motor shaft for screwdriver. This will hold the shart still while you unscrew the impeller. The shaft seal is a precesion part so be careful when replacing it.
Let us know if this helps, Robert
May 16, 2012 | Craftsman 1 - 1/2 Hp Pool Filter Pump
I had a Smith 1HP pool pump with a square flange on my Haywwod sand filter. After 12 years it died. The pool shop sent me home with a Emerson 1hp., 1081 pool motor. It doesn't pull the water like the...
Sounds like there is an impeller problem. A 1hp emerson should be fine. Take it apart and recheck impeller and diffuser. I am assuming they gave you a new seal to replace with the motor.
Apr 26, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
LOOKING FOR HAYWARD IMPELLER 1 HP EMERSON
Is there a number in the old impeller or do you have the model number of the pump?
John
Mar 07, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Where can i order the impeller (center dish cover) for a emerson 1081 3/4 hp pump
Feb 07, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
I want to replace all the o rings, i have seperated the moter from the body, but i only see 2 orings that i can replace, there are 4 other bolts i removed but i can not seperate the pump from the impeller...
THERE IS THE TANK GASKET THE DIFFUSER O-RING,LID O-RING AND THE SHAFT SEAL.. ITS A 1000.. ASK YOUR LOCAL POOL SUPPLY FOR A PAC-SEAL 1000 .. CLICK HERE TO SEE HOW 2 REMOVE YOUR PUMP .. PRIME THAT PUMP AFTER A REPAIR ... HOPE I WAS OF HELP.. IF SO .. VOTE .. Jay
Jan 29, 2011 | Pentair 2 hp WhisperFlo InGround Pool Pump...
Leak off pump housing
Sidewinder, sounds like it's leaking from the pump gasket or the water seal assy on the impeller. Check the locking ring to the pump housing and see if you can increse the pressure to the tub. Also check the tightness of the motor fan assy. to the impeller assy. tighten if necessary. Pump gasket part number is 912529. Impeller seal part number is 903494. Catriver..post back.
Oct 23, 2006 | Jenn-Air 24 in. DW731 Built-in Dishwasher
Pool & Spa Logo
221 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Mike Squire
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
