Question about Philips Hopper XG20 Impact Multimedia Projector
Why is it when i turn on my philips hopper xg20 impact projector, the color looks hazy, almost like double vision? I tried adjusting the settings an such but the picture looks distorted still? Is there any solution?
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: philips hopper xg20 impact projector
change the lamp and reset the lamp timer. it's time is up.
Posted on Aug 10, 2009
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
My projector shows diferent color, green on the top and normal color on the botom but it shows image
the light polarizer on one of the lcd panels is fried due to excessive dust and heat and will need to be replaced. unfortunately, you cannot get individual parts of the optical engine from philips, so you'll have to replace the whole optical engine.
Dec 17, 2009 | Philips Hopper SV20 Multimedia Projector
Philips big screen hazy/color problems easy fix?
Projection TV sets have two common problems. The first is known as a convergence problem. Common symptoms are....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy CRT fluid in the lens.
Common Symptoms - you TV may have one or more of these...
  • Dull Video
  • Bright video - whiteish
  • Redish video
You can see some example photos and find a solution here...
Nov 28, 2009 | Televison & Video
No power
If there is not power to the bulb and socket, check power coming from power supply with a voltmeter. You can remove the cover and see if the fuse is good. The fuse should have a little thin wire running all the way across it.
Aug 07, 2009 | Philips Hopper XG20 Impact Multimedia...
Philips Hopper SV20 Impact Multimedia Projector doesnt power up
hi the power supply of your unit is burnt refer service personnel
shyam
+919867355202
Feb 08, 2009 | Philips Hopper SV20 Impact Multimedia...
TV turns on and then, after a few seconds, picture changes to "double vision".
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | RCA P46921 46" Rear Projection Television
Double image or shadow image
We recently had the same problem with our church projector and we too had just changed the lamp. I read somewhere while searching for an answer that if the cable input is loose it will cause double vision of the text. Sure enough, the cable was loose and after tightening the text cleared up immediatly.
Dec 26, 2007 | Philips ProScreen 4750 Impact Multimedia...
Help
Your convergence might be out.Go to convergence settings and try the setting and it can be done electronically.
Jan 20, 2007 | Philips ProScreen 4600 Impact Multimedia...
Philips Hopper XG20 Impact Multimedia Projector Logo
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
