Question about Olympus Camedia C-5050 Zoom Digital Camera
Zoom lens not working
My son dropped our Olympus C5050 zoom camera and now the lens won't zoom out. The motor tries to push out the lens but nothing happens. Can I replace the lens on this model?
  • Jonesroo Nov 15, 2008
    I was on a cruise Oct. 12,2008 my Olympus C-5050 fell off the seat of the Bus and the zoom lens would not extend, it tries but will not extend.
    Please tell me what you reccomend
    My E-Mail address is Jonesroo@juno.com please let me hear from you.
    Thanks
  • oldromrider Feb 12, 2009
    I havn't dropped my camera but have a jammed lens. Again the motors are trying to push the lens out but fails. It makes to attempts I assume because if your like me you forget to take off the lens cover.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey cjk1234,
You can replace the lens on the camera through a authorized service technician, but often with digital camera repairs the cost of the repair exceeds the price of the camera. I would have the camera looked at by an authorized service tech.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Apr 25, 2008
Can I update firmware on an olympus camedia C5050z camera ?
There has never been an update for the firmware of the C5050 zoom. On Olympus they only offer some updates for Mac and Windows, to improve connection (driver) and a RAW plugin.
May 02, 2014 | Olympus Camedia C-5050 Zoom Digital Camera
Olympus C5050
That's a crying shame.  I believe that spares are no longer available for this unit (which is, IMHO, one of the very best prosumer digitals ever built).
Your best bets would be to take it to a local camera service center, or, to look on eBay for a used C5050 or C8080 (8MP with most of the same capabilities and some improvements, but, not quite as good an aperture) for a very reasonable price in good condition.
I know that's less than ideal, but, after a great deal of research on a similar problem with my C5050, that's where I ended up.
Sep 22, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
'zoom error' on olympus sp-560 uz
I had this problem and managed to fix it. The camera was dropped on a stone floor and the zoom error was present every time it was turned on. A ring or other piece of the lens was bent or damaged, in my non professional opinion. A profesional repair is my advice. However you may try my fix at YOUR OWN RISK.
Switch camera on, when zoom extends, but before it closes down due to zoom error, gently but firmly push lens back in. Drop batteries for camera to reset itself. Repeat, if necessary.
My camera now operates fully and when the lens extends it now no longer makes the slight grinding noise.
Good luck and remember at your own risk.
Jul 30, 2008 | Cameras
Zoom lens Motor Problem?
The suggests the zoom control failure
Only Olympus can fix it to it will have to go back.
Nov 08, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Zoom lever (Olympus Camedia C-8080 Wide Zoom Digital Camera ) does not work
If you can get to the ribbon cable that the zoom lever is attached to, you can use a multimeter or a continuity tester to see if the lever is actually shorting any traces on the ribbon. the zoom lever acts upon a motor that rotates the iner lens barrel, possible the motor lead is open or the switch under the lever is dirty/faulty.
Oct 21, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Dropped Camera Zoom Problem
Afraid not a novice or even an expert can fix this one. It will have to be a repair of the zoom mechanism. It will almost certainly be costly. Check your Olympus support site to see what your local repair options are.
Aug 30, 2007 | Olympus Camedia C-765 Digital Camera
Olympus Camedia C5050 Zoom
The unusual beeps usually occur when the lens cannot be extended or retracted, often due to dirt in the gearing or the lens cap being left on.
Try using canned air to blow around the outside of the extension cylinder, and, putting a fresh set of batteries in the camera (it probably got stuck on since it couldn't fully retract the lens and didn't complete the shutdown).
If that doesn't work, try taking it to a camera store with repair technicians and having them take apart and clean the lens extension/retraction mechanism.
Aug 19, 2007 | Olympus Camedia C-350 Digital Camera
Zoom malfunctioning
This sounds like there is debris lodged in the zoom gears. Been to the beach lately? The gears in the zoom mechanism are very small, and even a tiny spec of sand or other debris can jam them up. Alternatively the sensor inside the lens that feeds back the position of the lens to the control circuit may be failing - so the camera thinks the lens has retracted all the way and stops. If the stoppage of the zoom action is abrupt then it is probably debris, if it is a smooth stoppage like the camera is stopping on purpose it is probably a position sensor. Either way the camera will require repair. David Millier Advance Camera Repair
Feb 20, 2007 | Olympus SP-350 Digital Camera
I need to know how to remove the zoom lens to clean a water spot inside.
well u can, but u will need to know what are u doing, i repaired many lens when i worked in olympus, but gives lots of work.
Dec 14, 2006 | Olympus Camedia C-5500/C-55 Sports Zoom...
Olympus Camedia C-5050 Zoom Digital Camera Logo
339 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
