Ten key I have a Sharp Comept QS-1760A ten key and I need to know how to use the memory and storage. Relaxeh
  • 667 Answers
Hi relaxeh - not sure if you ever got the info you needed. If not, I'll give you a link for the user's guide. I could tell you how to do what you want to do but I've found it's always easier if your looking at the guide yourself with the pictures. If you already had the info, great. If not and this solves your problem, PLEASE rate this as fixed. If you need any more help just add a comment and I'll be happy to assist you further. Thanks.
Posted on Apr 30, 2008
My TI-83 has the result that ln10E4 is 11.51 when it should be 9.2. Is there a different setting under MODE that I need to change?
The natural log of 10E4 is about 11.51. The natural log of 1E4 is about 9.21.
Do you want the log of 10 to the fourth (ten thousand) or of 10 to the fifth (one hundred thousand)? What keys are you pressing to enter the argument? If you press 1 0 2ND EE 4 then you're inputting ten times ten to the fourth or ten to the fifth. If you want ten to the fourth, enter it as 1 2ND EE 4 .
Feb 04, 2015 | Texas Instruments TI-83 Plus Calculator
I have a 2003 buick regal and for some reason everytime i go to turn the car off and leave it for it a bit, and then go back to start it again, it doesnt start! i checked the battery, the alternator, and...
you need ignition switch ,its loseing it passlock memory, turn key on all the way just before starting let it set 20 min. w/ key on ,turn off for ten sec. and turn back on for ten min. turn off and start the car it now has resync ed the pass lock code , if this happens more frequently , get the ign switch and tumbler replaced you are on borrowed time from being stranded hope this helps
Apr 10, 2013 | 2003 Buick Regal
Wife used cig lighter adapter last night to blow up air mattress this morning new battery less than 1 month old wont start car. charged battery now when i turn the ignition key to start car the car alarm...
turn the igntion on, don't start, let it set for ten minutes Turn it off for 5 seconds then try to start it. If it lost memory for some reason and doesn't start . then do this three times , after the third time start it. that is the relearn procedure. Have a charger on it for the 30 minute relearn. Relearn is on for ten m off five s on ten off five on ten off five then start
Jul 02, 2011 | Chevrolet Lumina Cars & Trucks
When tv comes on it says replace lamp and reset timer i replaced the lamp but how do i reset the timer have a 56;; sharp rear projection tv
unplug your tv and hold the power button for ten seconds then plug it back in if that doesnt work leave it plugged in and then hold the power button for ten seconds.
Jan 13, 2011 | Sharp 56DR650 56" Rear Projection HDTV
I dont know where the power of ten button is, it is really confusing, when you dont know where it is when doing equations on your homework.
To enter an exponent of ten, use the EXP key in the middle of the bottom row. For example, to enter 1.2 times 10 to the 7th, press
1 . 2 EXP 7
If you want to raise 10 to a value, use 10^x, the shifted function of the LOG key on the top row.
Oct 19, 2010 | Casio FX-260 Calculator
2002 Monte Carlo Security system has shut car down completely unable to start car
the process takes about thirty minutes. in three ten minute key cycles. here is how you do it . make sure that the battery is fully charged. step on parking brake pedal and leave it down this will keep the head lights off. turn the key and try to start it then leave it in the on position. you have to leave the key in the on position for ten minutes. you will see the security light on. after the ten minutes the light will go off then turn the key to the start position. turn the key all the way back to the off position and count to three. then try to start it and leave the key in the on position for another ten minutes till the security light goes out. you have to do this same process three times to reset the security system. sometimes you get lucky and it will start after the first ten minute cycle.
Oct 31, 2009 | 2002 Chevrolet Monte Carlo
Hitachi ft 5500 tuner, tuner pre set problem
I bought an FT-5500 in 1983 that I haven't used for ten years but I still have the manual which states the following re pre-sets:
1. Tune into the station to be memorised with the tuning key.
2. When the memory write key is depressed the memory write key indicator lights continuously for about 5 seconds after the FCCS operation with FM reception and immediately with AM reception. One of the 10 preset keys is depressed for memorising the station while the indicator is lit. When the key is depressed the indicator goes off, the memorizing operation is completed and the next time you want ot listen to the station it can be recalled by depressing the corresponding preset key.
If the preset key is depressed during this interval and the FCCS data & broadcassting station are memorised the indicator goes off.
There is more but I think this should be enough to get you going.
Apr 25, 2009 | Electronics - Others
Uniden 900MHz phone model EX17960A
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
Each pause counts as a digit.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
number has been stored.
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
Dialing a Stored Number
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
beep rapidly, and the phone will not dial.)
Nov 13, 2007 | Lands Phones
Accident, locking keys
you can unlock the projector as under:
press these keys within ten seconds as written in the order.
Nov 05, 2007 | Sharp Notevision PG-M20XU Multimedia...
109 people viewed this question
