Question about Garden
Problem with the Pond & Water Garden Pump Off power Orbit watermaster 27956 it does not matter if i work it manually. the timer kicks on and starts counting down but the sprinkler system is not working the timer says power off in the little water drop on the display. I have checked the fuse and it is good. The timer seems to be working properly except for actually turning the sprinklers on'
SOURCE: I have an Orbit WaterMaster Sprinkler control, it
There are 3 things this "off power" "light bulb" could be. Blinking red light? means fuse has gone out. Check the power source where the unit is plugged in to. Is the GFI popped out? plug something else like a fan or something into the socket to test. the third thing is a short internally. Call orbit technical assistance. they're great.
Posted on Jun 23, 2010
SOURCE: Off power Orbit watermaster 57196
I am having the same problem, did anyone find the solution to ths?
Posted on Sep 16, 2010
SOURCE: I have a Orbit 57161
Manual:
http://www.orbitonline.com/lib/media/57114-14%20rF_Eng.pdf
Website:
http://www.orbitonline.com/products/Timers/02/01/19/671/
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Posted on Oct 06, 2010
  • 157 Answers
SOURCE: My timer counts down but no water is coming out of
If it only one head/zone that does not work, it may be that you have a bad solenoid for that head/zone. Check the solenoid for any visual hints that the solenoid has failed, such as rust, and recheck that all wire connections are still waterproof. Another possibility may be the transformer, check is the resistance if you see an infinite reading then it will need to be replaced. Here is a link that may be of assistance: http://rainbird.custhelp.com/app/answers/detail/a_id/17
Hope this has helped you, and plese don't forget to rate us. Thank You.
Posted on Mar 20, 2011
mark24354
  • 776 Answers
SOURCE: We have an above ground
Sounds like this is an issue of gravity allowing the lower level fountains to take all the water from the central (higher) fountain.
The pump needs to either be much stronger OR you will need to restrict the flow out of the lower fountains until the upper fountain starts to work OR reduce the number of lower fountains (this is just another way of restricting the flow out of the lower fountains).
I don't have details of your pump and fountain models but you won't get water up to the higher fountain if it can flow out of the lower fountains faster than you can pump it.
Good luck.
-Mark
Posted on May 21, 2011
Battery location orbit watermaster sprinkler timer 57194 or 57196
usually located on back or bottom near the selector buttons
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 11, 2017 | Orbit Hardware & Accessories
Mod 57880 am setting ok pm setting wont come on ?
Is this new timer?
Or timer that worked before and stopped working?
Check outlet with circuit analyzer for correct polarity and grounding.
Reset timer and re-program, being careful to avoid conflicts and/or overlaps. Each ON time must also have OFF time with consistent days for each. If selected time is 12:00, then use 11:59 instead to avoid possible problems with am and pm conflict.
product comes with 1 year limited warranty.
Orbit digital 57880 sprinkler timer manual is 19 pages long, which is good argument for using analog timers with 1 page manual.
Troubleshoot appears on page 18 of manual, and includes Tech service number.
http://waterheatertimer.org/pdf/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Oct 04, 2012 | Orbit Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
I have an Orbit WaterMaster Sprinkler control, it is hooked up, but there is a light bulb that says power off and the sprinklers won't turn on. They will turn on manually at the sprinkler station. Can...
Apr 11, 2010 | Orbit Sprinkler System Power Source...
Looking for manual Orbit Watermaster 57012 Controller.
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57004-57006-57008-57012-before-2002-Sprinkler-Controller-Owners-Manual.pdf
Jan 10, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
Jul 07, 2009 | Garden
The instruction manual got wet and I cannot read how to program the Orbit Watermaster 62015/91600. please advise
Assuming you have the four dock kind, here's the link to the pdf manual online. Otherwise, you can search their website for the correct manual.
http://www.orbit-irrigation.com/lib/media/62032-24ErE_001098.pdf
May 12, 2009 | Orbit 2-Dial Hose Faucet Control Timer...
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
