My tv for the past 9 months has been turning it self off and on this would last from 30seconds to 5 minutes would come back on.. however it is off for hours at a time now.. the lights on tv [on and offf light greene and red are off as if tv is unplugged] the model no. is dlp 52sz8d-ua could you tell what you think it might be and tell me how much the parts would cost [worst case] i know this hard to find being an interminent trouble which are worst troubles to solve. please tell what you think could be trouble thanks larry
  • freaky51 Aug 03, 2010
    yes thank you
  • 11,800 Answers
Since the lights are completely off then it's a fault in the power source or one of the main consumers - bulb (and ballast) or processor - it triggers a complete shutdown of the source. To find which you must test it while it's dead.
Worst case - a faulty bulb has fried the source - $300 for parts only.
Posted on Aug 03, 2010
Ask question fixya
have a pressure test done on the fuel manifold to check for pump-regulator pressure and filter performance. You state that the filter was last changed in 2007 so it is well past it's blocked up date .. Run fault codes . replace the canister . Have a compression test done as the engine is getting long in the tooth and may need refreshing .. Check that the cat converter is still operational as they will block up the exhaust system and cause poor performance
Mar 02, 2014 | Mercury Sable Cars & Trucks
TV Turned Itself Off - Now - No Power No Lights Flashing
power supply board is faulty need to check the power transistors and fuses u will need a tech to solve this
Jul 14, 2013 | Samsung HL-R6167W 61" HDTV
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
Sony WEGA KV30HS420 shuts itself off
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Sep 23, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sound, no pic
THE PROBLEM IS SIMPLE, THEY MAKE CHEAP VIDEO BOARD CARDS THAT BURN OUT WITH SHORTS, YOUR ONLY REAL SOLUTION IF NO ONE IS GONNA FIX IT FOR FREE, LOL. IS TO BUY A NEW TV BECASUE REPAIR OF THIS ITEM, LAST TIME I CHECKED WAS CLOSE TO 400 BUCKS. HD TVS ARE CHEAPER NOW THAT THERE MORE AVAILABLE SO GO GET YOUR SELF A VAIO ON SALE TODAY AT WAL MART
Sep 11, 2009 | RCA L32HD32D 32 in. LCD HDTV
9 blinks,won't turn ON, but I can make it turn on with diagnostic
I'm suprised with nine blimks the set will turn on at all. You are in the service menu; be careful, you can render the set totally unusable if you change something. Try unplugging the set for a few minutes and plug back in.
Mar 30, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony 62' blinking lamp light
you might want to have the thermal fuse checked... seems to be an issue... sony knows about it but doesn't want to share this info with many.
amazing how you can spend big bucks on a tv and the life of the tv isn't all that long.
kim
Jan 16, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Ilo Flat screen
if your tv is on warranty take it back to supplier for another.if the warranty has expired have a tech repair your tv the Audio,or power is defected good luck.
May 14, 2007 | iLO 2600 Television
Flashes orange 2 times every 5 seconds
There is a 20 pin cable that goes from the main board to the light engine that can cause this issue. The other possibility is the door switch or the cable that leads to it has failed. If none of those correct it then the light engine itself is the problem. Hopefully one of the earlier mentioned items is the issue as the light engine is costly. The part number for the cable is LSJA0467 and is available here http://www.partstore.com/PartNumberSearchResults.aspx?PartNumber=LSJA0467
Mar 26, 2007 | Panasonic PT-43LC14 Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
