Question about Xerox WorkCentre XD130DF Laser Printer
J2 drum cartridge light no after replacing drum
After replacing drum the light is still on and will not let us make copies
  • 239 Answers
Not having the service manual, sometimes the NVM gets corrupted on these machines.
The NVM can get corrupted and cause these error messges to appear especially when inserting a new copy cartridge.
Not easy to correct.
Reinitilazing the Main PWb can take care of these types of faults.
If the main pwb needs to be replaced the drum unit and developer housing needs to be replaced as well.
All the parameters need to be rechecked and can be done by a Xerox Serivice Representative only, to check for critical areas.
Posted on Oct 16, 2009
    President:
  • 2,072 Answers
J2 is the indication that the Drum Cartridge life has elapsed. The possibly exists that the Customer has installed a New Drum Cartridge. The Customer would be directed to change their Drum Cartridge by their User Guide. This action on the part of the Customer will cause the Drum Reset Switch to actuate for a moment when the Side Door is closed. This is with the provision that the Drum Reset Circuit is working properly. That momentary actuation of the Drum Reset Switch, being actuated by the New Drum, resets the Drum Counter. Should something be faulty with either the reset mechanism on the New Drum Cartridge, or the Drum Cartridge reset Switch circuit, the Counter will not reset. Note: A new Drum Cartridge will NOT reset the Drum Counter unless the machine is holding a J2 presenton the display. The first revolution of the Drum will render the Drum Cartridge used. A Used Drum Cartridge will NOT be capable of resetting a J2. Again, one revolution of a new Drum Cartridge will render it to be a used Drum . Cause:
Posted on Apr 28, 2008
  • Rick Kasper Apr 28, 2008
    Ask the Customer to show you a receipt or invoice to prove that they purchased a Drum Cartridge from Xerox, or one of the Major Office Supply store such as Office Max or Staples. Without a receipt, or proof of purchase, the Customer should be directed to order and replace the Drum Cartridge.
    If J2 remains after a Xerox Drum Cartridge replacement:(Tip 154504)
    a-Enter Diagnostics Input Code 30-01
    b-Actuate the Drum Reset Switch while observing the UI Display indicator labeled 50%-200%. The LED should glow when the Drum reset Switch is actuated. This would indicate that the Drum Switch circuit to and from the Main PWB is OK. ( See*Note)
    c-If the led glows when the switch is actuated, perform a Drum Count Clear Diagnostic 24-(07). Check that the 22-(12) Diagnostic Code shows that the Count has reset. This should conclude the Service Call.
    *Note: If the UI Display indicator labeled 50%-200% is not glowing or glows continuously when the switch is actuated or deactuated, continue with step d.
    d-Remove the Control Console.
    e-Unplug the 2-wire connector CN902 on the Control Console .
    f-Check at connector CN902 between pin 1 and 2 for a resistance reading not more than 1 Ohm (Do Not trust continuity beepers for this test). With the switch actuated the resistance reading should go to infinity. If not, the Drum Reset Switch is broken internally. There is no part that can be ordered to replace this switch. The Switch must be acquired from Scrap and Salvage efforts. Contact your parts District IOM for process directions.
    g- If the Drum reset switch is good, reconnect CN 902 to the Control Console, and reinstall the Console onto the Copier / Printer.
    h- Disconnect CN20 on the Main Pwb of a Pro 16 or Pro 215 Families (CN 116 on the XD100 Family) and check the resistance of the top 2 pins on the Ribbon Harness while the Drum Reset Switch is actuated and released. Again the readings should be Zero Ohms and Infinity. If not, replace the OP harness ( PL 7.4 item 4). The Control Console itself could also cause this problem (PL1.3 item 8).
    Note: The Control Consoles on the XD100 and XL2140 Families will have different part numbers. Use the PL 1.3 hyperlink below for those Machines of the XD100 and XL2140 Families of Machinery (PL1.3 item 8). The XL2140 Family are not clearly noted on the Edoc. Field Engineering ETI (Tip 164382 - PLI) contains an attachment for the XL---- Family that will clarify the parts needed for the Control Consoles on those products.
    i- Reinstall the Ribbon Cable, and repeat the steps a to
    On the front of that drum, there is a green cover. Take it off and what has happened is the flag on the gear had dropped in shipping.
    You will see a flag like piece of plastic on one of the gears, reset it to up and somewhat to the right.
    Then put the green cover back on
    That flag has to be in the up position when new. It passes down and actuates a drum reset switch on the machine.
    When that is back in the up position. re insert the drum and on the first revolution it will turn on the switch.
    I can try and send you more information if you provide an E-mail address, or simply take the drum back to where you bought it for exchange.
2 Suggested Answers
  • 2072 Answers
SOURCE: J2 Error on XD125F
With that machine, what frequently happens is the flag in the drum unit falls down during shipping and does not swipe the drum replacement switch.
You can do one of 2 things, Exchange the drum cartridge or, on the front of the cartridge you have to remove the green cover, Remove the clip and pop off the gear cluster. Then look at the one gear in particular that has a flag like protrusion. Rotate it so that it stops up and to the right, so that when you place the drum back into the machine it can rotate down and hit the switch that tells the machine you replaced the drum.
That flag only runs a half turn, one time at install. And if it has fallen in shipping hte J2 will not clear.
That is what has happened. It is pretty common.
Posted on Sep 17, 2008
Getting J2 on the screen copier won't work
That means the drum cartridge has reached the end of its life.
You can replace the drum unit or the chip on back.
You can google a business called "the parts drop."
They should have both.
Jan 19, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
HI, MY XEROX 1045 COPIER has making ""clicking"" sound
That indicates you need to replace the drum cartridge. It's been a while since I supported those products, but I believe the cartridge is in the bottom of the device. Make sure you remove the toner cartridge before tipping it over or you'll have a mess to clean up and won't be able to remove the drum.
Once you replace the drum, you need to reset the copier.
Nov 17, 2009 | Xerox Office Equipment & Supplies
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
Xerox XD100 that is showing a code J2
No. The CRUM is integral to the Drum Cartridge. The only way would be to swap CRUM from a cartridge that failed for a reason other that it reached end of life.
Jul 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
J2 ERROR
Replace the Drum Cartridge.
Jun 26, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
J2 Error on XD125F
Sep 17, 2008 | Xerox WorkCentre XD130DF Laser Printer
We have a xerox 2520, that has a J2 error code. We can't fix a service rep locally.
1. turn off XD125f
2. Turn on
if not try again
6. turn off
Sep 16, 2008 | Xerox Office Equipment & Supplies
Printer Stopped
J2 is the drum cartridge, or some people call it print cartridge has reached the end of its life.
J1 is the toner cartridge, J2 is the drum.
Jul 17, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD130DF Laser Printer Logo
1,713 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
