Question about Linksys Wireless-G WRT54G Router
Routers how far away in distance can the next computer be? Does the transmission go througth walls?
    Master:
  • 555 Answers
Yes, the wireless signal will penetrate walls. How well they will penetrate depends on what the walls are made of and contain.
With no obstructions, the best case scenario for 802.11G (which is what the WRT54G uses by default) is a signal range of about 140 meters.
In a normal home environment with wood frame construction, a practical maximum range will be more like 40 meters.
Brick, concrete, aluminum siding, etc will diminish this even more.
Hope that helps. Good luck!
*If you find the solution helpful, please rate it!*
Posted on Apr 25, 2008
  • 145 Answers
Our office network uses the router it goes through three walls to the other side of the warehouse for about 70 feet.
My HP notebook wont connect to internet unless im next to router. what do i need to do to be able to access internet in another room
what notebook (model
what router,. name and model , endless choices here.
the router can be bad, how old is it, ?
what room, how far.? 10ft, 100 feet? distance matters.
is home wood, or concrete walls or brick walls.
the RF energy is weak and does travel far.
unless only air is between point A TO B.
Ever drive into a tunnel and have radio go dead, same thing happens here.
as you walk , look at the signal strength. see it drop
the lower it goes, the slower it goes.
or you are using same channels are your neighbors.
use the program to learn how to stay off busy channels.
the rounter
insidder 4,
learn how wifi works then play with this magic tool,
I run my channels where others are not.
http://www.metageek.com/support/downloads//
May 01, 2017 | HP Computers & Internet
How far it works ?
The strength of the wireless signal depends on the SQUARE of the distance between your computer and your router.
It also depends on the thickness of walls, and the materials inside the walls between the computer and the router.
Feb 15, 2015 | Computers & Internet
Netgear65 n750 not effective 40 ft. away
If the router has "N" value it should run a good distance away, even to the neighbors home. If "G" 30 Feet to 50 feet max.
40 Feet is difficult if passing through thick walls or steel buildings. If it is not an "N" router, then you need that or an Extender system. See TigerDirect for hardware replaements.
Apr 15, 2014 | NetGear WGR614 Wireless Router
How far can a computer be from a router and still work
if there are no line of sight issues or interference or obstructions then you can be atleast 300-500ft. however in homes depending on the building materials etc it could hinder your wireless signal and strength.
Mar 07, 2012 | Computers & Internet
How can i bost the signel on a linlsys E1000
Make sure the latestwireless card driver is installed in the computer.Locate the wireless routerhigher and away from concrete and brick walls, foil-insulated walls. Locate the wireless routeraway from cordless phones and microwave ovens these can cause interference.You could be gettinginterference from other wireless access points or wireless routers in yourarea. Check the wireless broadcast channels in your area, and select one thatis unused or one that has the weakest signal strength.
Feb 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
My touch hd could not connect to my home wifi although the connection is visible/detectied.
Even though it is visible and detected the signal strength may not be strong enough to establish a connection. Various factors affect connecting a device to the internet with a WiFi connection, including overall signal strength (G Routers are the weakest), distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your device is too far away or, has obstacles in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and/or there are obstacles. Try connecting right next to the router and see what happens. Also, make sure you are putting in your router's WEP key in correctly.
May 13, 2011 | Computers & Internet
When watching a movie using my wii console. everytime i log on the internet w/ my computer. I loose wi-fi connection to the wii. and get an error code 52230
Error Code 52230 means that your router or Internet Service Provider is having difficulty assigning a DNS or IP address to the Wii. What this usually means when you had a connection and it drops is that you aren't getting a clean signal connection between your router and your console. First step, unplug your modem and your router wait 30 seconds and plug them back in. If that doesn't work:
Various factors affect connecting a Wii to the internet with a WiFi connection as well, including signal strength, distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your Wii too far away or, has obstacles (walls and ceilings) in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and the router or if there are obstacles.
In your case it could be the wireless adapter on your computer is interfering with the Wii. Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
May 11, 2011 | Nintendo Wii Console
L would like to increase the distance of my linksys160n to get to a lpltop 200 feet away.. please help
Hi
not sure if the router far will reach that far due to interference within your network. just try to change wireless channel to 9 or purchase a range expander.
Sep 12, 2010 | Linksys WRT160N Wireless Router
How far away can my wireless G router be from my xbox adapter
It is about 50-75 feet depending on how many obstructions are in the way (Walls, Ceilings, etc)
Oct 23, 2009 | Microsoft Wireless Network Adapter Xbox...
Netgear router AAAAARRRRRRRRGGGGGGGGGG
You did not mention if this is a wireless or wired connection. I will assume wireless for now. Since you are 4 feet away, you cant get any better reception than that.
When you go into the kitchen, you can have several things interfere with the radio signal. First is distance, how far away from the router are you? Second, what does the signal have to travel through to reach your laptop. What kind of walls, what is in those walls that can interfere with the signals. Do you have a lot of metal in your kitchen, that can act as a signal shield, preventing the signal from reaching your laptop. The high voltage wires in your kitchen walls can not be good for the signal.
What items in your kitchen can cause Electromagnetic interference (EMI). The motors in a refrigerator, or a blender will cause EMI.
Look at your laptop, it should tell you the signal strength. You will have to bring up the software that monitors your wireless connection. See how far you get from the router before to drops off.
If the router is not on the same level as your laptop, this will cause problems. Is your router in the basement or upstairs in a den or something like that?
Feb 17, 2008 | NetGear DG834G Router
Linksys Wireless-G WRT54G Router Logo
168 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
