Question about Canon EOS 10D 35mm SLR Camera
I have Cannon EOS Rebel xsi. The camera does not take picture when press the shutter in all modes. There is no error message. Have change the memory card, recharge the battery and none work.
    Genius:
  • 1,234 Answers
Hello Sure !
The probleme :
The Shuteer Has A cable Connected to Recorder
Maybe The cable Has Cutted when you Shut ,or Maybe Cutted When You Charged The Battery cause When your put your camera on the charge , the cable goes be hot and it should be cutted .
Solving The Probleme :
1) I advise You To Change The Cable
2) Push The Reset Button
3) Charge It Again
It works 100%
Fix-shad0w
Posted on Aug 03, 2010
My Cannon Rebel XSi when pictures are taken are blurry
Try using manual focus. Make sure your auto focus points are correctly set. Look for button that looks like matrix. Press it then use/press joy stick type button to select auto focus point.
Nov 20, 2012 | Canon EOS Rebel XSi Digital Camera
I have a canon rebel Xsi and the flash will not pop up.
Will it not pop up under ANY circumstances? Try putting the camera in Manual (M) mode, set the shutter speed to 1/200 and the aperture to F5.0, then go in a dim room. Press the button on the camera body with the flash symbol on it. Does it still not come up?
Feb 12, 2011 | Canon EOS Rebel XSi Digital Camera
Cannon EOS500D, taking a picture in creative modes I have to press the shutter button twice to take a picture.(not counting the half pressing of the shutter button. the second pressing of the shutter...
Hi kevinmullen8 - was this ever resolved? My mum was mucking around with my camera (eos1000d) and I have the exact same problem (press shutter twice in creative mode). Factory reset was of no assistance.
Please help!!!
Dec 05, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
CANNON REBEL XSI WONT TAKE PICTURES, SCENE SAYS CARD WRITE PROTECTED SO NOTHING HAPPENS WHEN TRYING TO TAKE A PICTURE
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 26, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon lens locks when taking a picture.
Mirror lockup is probably enabled. You can disable it by going into Menu and then Custom Functions. Select Mirror lockup and disable it.
Jul 14, 2010 | Canon EOS Rebel XSi Digital Camera
Half the picture is black
The black photo problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to cannon service centre. If your camera is under warranty period its well and good they will replcae the lense sensor for free of cost.
Thank you
Jun 10, 2010 | Canon EOS Rebel XSi Digital Camera
CANON EOS REBEL XSI 450D BODY WHEN TAKING A PICTURE ERROR 99 COMES UP
Unfortunately, the Error 99 code is a catch-all code that means an UNKNOWN error has occurred. Because of this, it is difficult to pin down exactly what is causing the problem.
It could be a fault with either the camera (main circuit board, software, shutter mechanism etc.) or even the lens.
For starters, I would make sure that the lens electrical contacts are clean and the lens is mounted correctly and fully locked home. If you have a spare lens, try that also.
Next, I would reformat the memory card (do this in camera). If you have a spare memory card, try that also.
Check that the battery contacts are clean, and also the contacts of any external hardware such as vertical grips.
If none of these solve the problem, the only option left is to take it to a Canon service agent :-(
Hope this helps,
Matt
Apr 30, 2010 | Canon EOS Rebel XSi Digital Camera
Can't take good pictures with new Canon Rebel xsi
You will need to read the manual. I f you have a basic understanding of how ISO, shutterspeed & Aperture width combine to determine the 'right exposure.
Try this:
Set the camera to Av (aperture priority mode). Half press the shutter button and see the light meter indicator to see how well exposed your shot will be. For most cases you would be aiming for a value of 0 (properly exposed). The metering mode determines what part of the frame is used to compute the correct amount of light. For starters begin with pattern metering. Try and aim for a shutter speed of 1/125 or more if you are using the 17-55 mm EF-S f3/5-f5.6. Try and shoot at 40 mm F/5.6 (in Av mode this can be set by rotating the dial near the shutter button.
All the best
Mar 29, 2009 | Canon EOS Rebel XSi Digital Camera
Canon EOS 10D 35mm SLR Camera Logo
82 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
