Having finally connected my 605 wifi to my tv set up, I cannot for the life of me find how to register my dvr station, that apparantly I must do, so that I can access the tv stations/programmes. I have tried on numerous occasions to obtain this information from the Archos 'technical support' mob but they do not appear to understand plain English and have been NO help whatsoever, which I find extremely frustrating. Also having purchased the web browser plug in I find I still cannot access the web, even though I have full broadband and wifi equipment in my office. All the networks that appear on the Archos are locked and apparantly I need WEP or WAP keys to get in, I dont know what these are (being a novice) but again Tech Supp could/would not help, WHY???? I have heard repeatedly what a fantastic piece of kit the Archos is, but after shelling out nearly £300 for this and that to make it work and to still be unable to use it after 3 months of trying is very frustrating to say the least. CAN ANYBODY suggest a simlpe solution to thse problems.
    Sniper:
  • 133 Answers
I am not really that familiar with your product but here are some links that might help you solve your problem. please let me know before leaving a negative vote as i can probably find more if you need it.
http://www.archos.com/support/support_tech/how_to_guides.html?country=global&lang=en
http://www.archos.com/support/download/guides/23.%20Making_a_WiFi_Connection.pdf
Hope theese help.
Posted on Apr 25, 2008
  • scott gregg
    scott gregg Apr 25, 2008
    also i noticed that the website said you needed media player 11 to watch stuff wifi.
  • 477 Answers
The pass phrase might be you serial number on the box. I know it is for alot of other wirless products. hope that might help.
  • Mike Johnson
    Mike Johnson Apr 25, 2008
    Please don't forget to rate the solution
    Genius:
  • 3,422 Answers
So all you want is the WEP key or WAP.Then y don't you reset your router to the factory defaults and then configure and setup the net connection.
Well this is the only solution..
Goodluck,
  • 19,396 Answers
You need to get the Cinema plugin to play .vob, .mpg and .ps files, and the Video Podcast plugin to play mp4, .m4v or .mov files coded in H264
The DVR station is used to record TV shows. Just plug the DVR station to your TV or Cable box or DVD player (you can record DVDs also) and hit record. The Mini dock is used for chraging but you also can connect to your PC with it and playback video to a TV (additional cable needed).
  • 1 more comment
  • Ginko
    Ginko Apr 25, 2008
    If it is not working , usually you are not using correct cable connection or you need to setup (for example) your DVD input to the cable you are using for connection. For example, if you are using RCA cables, then you need to switch your DVD input to RCA, s-video etc.
  • Ginko
    Ginko Apr 25, 2008
    To acess a wifi network instead you need to be the owner of the network, if you do not have WEP key or passphrase, that means that the network is from some of your neighbours.
    Do you have your own broadband wireless router connected to Internet,? if not you are not supposed to have acess to any wireless, it does not come for free.
    If you have a working wireless router with Internet , then you need to find your key from router control panel, or to configure the router.
    Let us know if you need more help with this.
  • Ginko
    Ginko Apr 25, 2008
    If you have a wireless router (ones with aerial) and broadband, then you probably need to activate wireless on router.
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
Set up of archos 605 wifi
can you provide the model numbers for the dvr station and hdd dvd player, please?
May 25, 2008 | Archos 605 WiFi Digital Media Player
No sound when I record from my TV
Are you using the DVR Station Gen 5 or DVR Travel Adapter?
Jan 23, 2008 | Archos 605 WiFi Digital Media Player
RCA cables and Home Movie Question
I have had my 605 for a week. The first thing I noticed is that all cables and connectors are special. No way to hook up standard RCA cabling to your TV. I have an AV 500 that is about three years old. Even the cables from it will not work with the 605. It seems that 605 was designed to cause us to buy additional equipment and add-ons. We can't even replace the battery, and its life is very poor; just over two hours!!
Also, I registered my product and got a password for their site. I have sent two questions to their service. Both time I was promised a reply in two days. I have heard nothing at all!! NOTHING! I am starting to wonder!!!
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
How do connect dvr station gen 5 to record off my tv ,
There are a lot of ways that the 605 DVR can be connect to the TV, If you let me know what TV you have I could make a reconditions - However the easiest method is to use a yellow/white,red phono cable
Jan 17, 2009 | Archos 605 WiFi Digital Media Player
Can I pre record on the archos 605 wi fi 30gb
You have posed a very good question with a very complicated answer. There are two things you MUST have in order to do what you are asking:
1) Your "docking station" cannot be the Archos mini-dock, b/c the mini dock has inputs only. Your docking station must be the Archos DVR Station - Gen 5.
2) You have to have a digital cable box, FIOS, or digital satellite box.
You will be recording from your cable, satellite, or FIOS box instead of directly from your TV. Hook the red, white, and yellow cable from one of the red, white and yellow outputs of your cable/sat/FIOS box to the specialized adapter of the DVR Station (make sure your Archos 605 is properly docked inside). Here is a link to the connection guide if you don't have it:
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
Once the connection is set up, you must follow the exact directions printed on pp.11-15 of the DVR Station user manual - it will require downloading several pieces of software. My only reccomendation is that you make sure that the Archos 605 is fully charged before proceeding, b/c if it loses power during the process, you may ruin your mp3 player. Here is a link to the DVR Station user manual:
http://www.archos.com/support/download/manuals/english_user_manual_dvr_station_gen5_v3.pdf
If you have followed the instructions exactly, you will be able to schedule your recordings to your Archos 605.
There are two catches that I noticed with this player - 1 major and one not-so major:
1) Not-so major: Your subscription to the TV guide that enables you to schedule recordings will only be free for 1 year
2) Major: The DVR Station forces you to choose between an NTSC and a PAL format when choosing a TV standard for playback. PAL is only for Europe, so never select it under any circumstances. NTSC is shutting down on February 17, 2009 - in a little more than a month. After that time, you may not be able to display the recordings that you have made to your TV itself.
-Tha Mp3 Doctor
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
CAN I PRE RECORD PROGRAMMES ON THE 605 WI FI 30GB
Archos 605 Wifi w/ Archos DVR Station Gen 5
-Tha Mp3 Doctor
Archos DVR Station & 605 wifi PMP
Not sure if this will help you or not, but I have a 404 and was having issues with the scheduler changing the channels for me also. Then I realized that it is a infrared transmitter - the same frequency as a remote I realized what I was doing wrong - Your archos station must be facing the cable box that it is turning on. I had my archos on top of the cable box and it was not working - but when I turned the cable box and the archos station to face each other - so the signal can transfer - it worked just fine. Hope that helps!
Oct 22, 2008 | Archos 605 WiFi Digital Media Player
Connecting to a tv
YOU NEED TO GO TO SETTINGS ANDCHANGE THE PLAY MODE TO PAL FORMAT
Feb 11, 2008 | Archos 605 WiFi Digital Media Player
Can only record in black & white?
try changing your Display/ TV Connection setting under the setting menu - it may need to be set to "composite" (not RGB) if connected as displayed in the instruction manual - worked for me anyway (hope it does you).
Jan 21, 2008 | Archos 605 WiFi Digital Media Player
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
