Question about Lexmark X6170 All-In-One InkJet Printer
Black ink cartridge
Our printer will print a black page or print the color and not the black. When we examined the cartridge there was black ink oozing out the bottom. this happened with the previous one as well. We thought that was just a bad cartridge, but know it has happened twice.
Try Cleaning the maintenace unit which Is located under the parked region of the cartridges ,left hand side of the unit. Soak up as much of the ink as possible and clean the wipers with a damp lint free cloth or towel.
Posted on May 06, 2008
My printer will not print anything. I have a full cartridge of black ink, but low on the other colors. Will it not print with the colored ink out?
Assuming the test print page prints using the black ink, printers have a setting that allows you to select black and white printing. If you need further help you need to include the manufacturer and brand of the printer. If the test page doesn't print the black ink and Since you say you have a full black ink cartridge I would also check that you completely removed the plastic tab/sticker that covered the hole the the inks comes out of and that the ink cartridge is securly installed.
Dec 06, 2016 | PRINTER Office Equipment & Supplies
Printer says "incorrect alignment" and
Possible causes of the error you got can be that one of the ink cartridges is low or out of ink or the paper has already been printed on or is colored paper or the ink cartridge is defective.You need to
examine the paper the alignment page was printed on. Does the alignment page print correctly?You need to perform an print cartridge cleaning procedure and Try to align the page again.
Mar 14, 2011 | Computers & Internet
New ink cartridges. Printer won't print and does not show the new cartridges.
Step one: Run the clean print cartridges utility
1.
Press the Setup button.
2.
Press the down arrow key.
3.
Select Clean Print Cartridge and then press OK . The device prints a test page.
4.
Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
5.
Open the Printer Toolbox . There are two ways to do this:
select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Features tab, then click the Printer Services button.
6.
The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
Step two: Replace the problem cartridge (you probably have a defective cartridge)
If a cartridge replacement was not tried previously to solve this problem, replace the problem cartridge now
Cause and prevention
Color mix is usually caused by a material touching the nozzles. Ink can wick along the material and travel from nozzle to nozzle. When different colors of ink mix in this way, the result is muddy, inaccurate colors.
Missing colors occur when the cartridge nozzles dry out, or when a color is exhausted because of specific printing demands.
Do not remove the protective tape from a new print cartridge until just before you install it. Once you remove the tape, do not reapply it.
After you have removed the protective tape, do not allow anything to touch the nozzles.
Print at least once a month to keep the print cartridges in good working order.
Always turn the printer off by pressing the button on the printer control panel, rather than by unplugging the printer. Turning the printer off properly allows it to protect the cartridges.
If you are removing a cartridge from the printer temporarily (for instance, removing the black cartridge in order to install the photo cartridge), put it in a cartridge protector.
If you do not have a cartridge protector and need to remove a cartridge temporarily, put it in an airtight plastic tub. Make sure nothing touches the nozzles. Do not use a plastic bag. If you intend to store print cartridges in a tub for a long period of time, place color cartridges with the nozzles down, and black cartridges with the nozzles up.
Nov 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Color ink want print after installing new cartridge
have you installed the cartridge correctly??? make sure you did
try to print a few pages, to get the ink going.
try test pages, try the aligning procedures as well.
Mar 26, 2009 | Lexmark Z515M InkJet Printer
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Picture crops strange
HP Photosmart 7550 printers
  1. Ensure that the memory card has been removed from the memory card slot.
  2. Make sure plain white paper is loaded into the In Tray.
  3. On the control panel, press the Menu button. Using the directional arrows, select Clean Cartridges .
  4. Press the OK button.
  5. After confirming that paper is loaded into the paper tray, press the OK button.
  6. Once the level one clean cartridge test page has printed, examine the printed page. If the print is not clear and/or there are lines in the color bars, continue to Step 7. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  7. Press OK to print the second level clean cartridge page.
  8. Once the second level clean cartridges test page has printed, examine the printed page. If the print is not clear and/or there are line in the color bars, continue to Step 9. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  9. Press OK to print the third level clean cartridge page.
Dec 08, 2008 | HP PhotoSmart 7550 InkJet Printer
F380
You are using HP's cartridge with the smallest output . So if you are printing 80 pages of text, you will have a problem by the time you reach 95 or 100 pages. If you are printing in color, you only have 1ml/color. Meaning 3 colors. But in order to print a red, it will combine a magenta and yellow to product 1 color. So 3 colors doesn't mean 3 ml worth of colors. Effectively you may only be able to print 10-20 pages of color then your cartridge is empty. The black cartridge has about 4-5ml of ink. So if you print a lot I suggest you get another printer.
Mar 30, 2008 | HP DeskJet F380 All-In-One Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Lexmark X6170 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
