Question about PSC Quickscan 6500 Handheld
QS6500 won't read one charector like 1,2,3,4,5 or a,b,c,d,e. It will read group barcode.
Programming tab suffix
This manual may have the right barcode images to program your scanner.
http://www.posguys.com/download/QS6500BT_Manual.pdf
If not, a call to the manufacturer is how I solved the "how do I program the scanner" issue I had to solve.
Best of luck! Jon : )
May 30, 2013 | Datalogic QuickScan QS6000 Plus Bar Code...
I have a new LS4278. I need to congigure it to read fedex barcode
All you have to do is create a rule to transmit only the 12 digits you want.
You can create a rule with the Programming manual or the 123scan software.
Both of these are available online at support.symbol.com. Here is a short cut:
http://tiny.cc/d400s
if you need additional assistance please let me know - Thank you, Kim Ganoe 800.933.2839 x251
Mar 05, 2010 | Zebra LS4278 Cordless Bar Code Reader...
N 93 not reading chinese charectors
you have to enable the unicode character support in your mobile phone. If it is not there then you have to install a software of that kind.
Jul 14, 2009 | Nokia N95 Cellular Phone
We are using Unitech PT630, HT630 for our stock audit at various retail outlets. we get wrong barcodes while scanning. Most of the times, scanner return only 4-6 charectors or part of the barcode is read...
Algunas simbologias de codigos de barras pueden dar lecturas parciales (como el interleaved 2 de 5). Entonces verifica lo siguiente: el lector laser este limpio, y en la aplicacion puedes restringir la lectura a un numero fijo (8 por ejemplo) para que solo lea codigos de barras de longitud fija. Some bar code symbologies can be read in part (such as Interleaved 2 of 5). Then check the following: the laser reader is clean, and the application can restrict the reading to a fixed number (8 for example) only to read barcodes of fixed length.
May 12, 2009 | Unitech 630D PDT 2.5MBRAM LR CCD SCA
QS6000 Plus with USB programing question
The document below programs the QS6500 Plus Scanner
R44-2805A Rev C
Available from
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
Jan 27, 2009 | PSC QS6000 Plus Handheld
Problems with very small Barcodes
Default settings set a global limit of 4.
You can set the global minimum code length by following the instructions in the user manual on page 24:
1) Start
2) Set Global Min Length
3) Scan the number on page 303: I.e. '0' followed by '3' to set length to 3
4) Set
5) End
Jan 09, 2009 | Datalogic PSC QuickScan QS6500 Handheld...
PSC Quickscan 6500 Handheld Logo
26 people viewed this question
Top PSC Computers & Internet Experts
Jax Planet
Jax Planet
Sardar Yasir
Sardar Yasir
Level 1 Expert
Tom Chichester
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
