Question about GE WBSR3140DW Top Load Washer
Leaves clothes soggy at end of spin cycle..not spinning fast enough to remove water from clothes
    Brigadier General:
  • 3,513 Answers
Hi
Wet clothes after the spin cycle may not be caused by faulty washer parts, but rather a blocked drain is a very good bet. Check the drain line for a blockage and try again. If your hose is kinked or bent, this can also cause a drainage problem. The failure of one simple part creates a larger problem for all the washer parts. What can cause a blockage? A number of items; paper left in the pockets of your jeans, coins or other debris, even socks. Check your hoses, and make sure your laundry has empty pockets for future loads.
Also your clothes remain wet after your washer’s spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
Please check the link bellow to diagnose what can be wrong with your washer….
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Theclothesarewetafterspinning
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 03, 2010
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
What causes the water not to spin out of the clothes?
Hi, it means that the machine is not spinning fast enough and pumping the water away. If its not spinning enough then you have to get the machine looked at as its not clicking on in the cycle for it to spin fast enough. You also have to have it set to wash cycle that has a fast spin. If it is spinning fast then you have to look at the pump to make sure its pumping the water away.
Mar 18, 2016 | Washing Machines
After spin cycle clothes too soggy
Please see the answer we gave some moments ago.
Feb 08, 2015 | Washing Machines
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
67 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
