Question about Timex Ironman Triathlon 50 Lap Digital Watch
Instruction manual to reset time - Timex Ironman Triathlon 50 Lap Digital Watch
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Is there an online instruction manual for Kenneth Cole Model KS3025?
i don't know about on line instruction.
but i could help you ....
there is two position for crown 1 and 2.
bring crown on position 2 and turn crown clockwise to change TIME, DAY & DATE.
bring crown position 1, and turn crown counterclockwise to change DATE.
your watch has Chronograph / Stop watch.
use that please press right TOP button chronograph will START, press again Chronograph will STOP.
Press bottom button to RESET Chronograph.
hope it will help 9k=
Jun 06, 2014 | Kenneth Cole Watches
Watch tells wrong time however many times io reset
Best thing you can do is download the instruction sheet from braun-clocks.com. Go to bottom left of page and click on Manuals search, then enter your watch model number in the box.
You need to calibrate the hands, particularly if you've changed the battery. Read the instruction carefully, it's a bit involved but it will solve your problem.
Jan 20, 2014 | Braun bn0087 radio controlled black...
I need to ''reset'' a Seiko alarm chronograph watch, purchsed in 1999 to display ''standard'' time, rather than 24-hour, ''military'' time. Any idea how I do this? Unfortunately, my instruction manual has...
You can get instructions from their web site "Seiko.com".
Click on "support" and then on " instruction booklets" and then scroll down the page and you will see
a list of watches.
Download the PDF for your watch.
Apr 23, 2010 | Watches
Instruction sheet
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 25, 2010 | Timex Digital Expedition Camo Chrono Watch...
Help to reset date, day and time on Timex T5G341
Go to timex.com choose country then click on the help tab at the top of the page. You will find a tab for manuals and downloads on the left hand side.
May 01, 2009 | Timex T5G341 Sports Radio Control Watch
Reset the time on my Casio GW300
When out of broadcast range for a time signal, the online manual procedure works for me: http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2608&submit.x=39&submit.y=11
Jan 03, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Timex Ironman Triathlon 50 Lap Digital Watch Logo
455 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
