Question about Sub-Zero 561 / F
Refridgerator won't cool below 45F. Fans are both working. Thermostat best setting is 1 because high numbers make fridge get even warmer.
  • pbenington Aug 03, 2010
    I've checked compressor- it runs continuously. Evaporator fan runs continuously. Both refrig. lines going to compressor (suction & liqiud lines) are hot. Could problem be low charge or a defective compressor?
  • 10,515 Answers
There could be a low freon situation. I doubt faulty compressor. At the same time i would say, it could be compressor relay.
If you have experience in repairing appliances, could take all precautions necessary and use multimeter - You could do a continuity check on compressor motor and all combination's. An infinity value on multimeter would confirm bad compressor.
On the side of the compressor you will see a box (maybe a cover) remove the cover if it has one and then remove the wire harness. next you will see the relay with the capacitor mounted to it. give the relay a tug and pull it off the side of the compressor. once you have it off pull the capacitor off and then give the relay a shake. If it rattles the relay is bad. if the relay does not rattle the compressor is bad and you will need to call a service guy to replace the compressor.
Other option would be - Go to a local repair shop and get an overload and relay ( cost around $50 ).Replace it. If the problem still persists, then it is faulty compressor.
Compressor's usually have 5 years warranty on it.
There is a nice troubleshooting tip written by me. Have a look at the same. It would only include simple steps :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Good Luck!!
Thanks!!
Posted on Aug 03, 2010
  • 6,784 Answers
If you are not hearing the compressor cycle on and off in intervals and there is no air flow present inside the unit, this will confirm that there has been a severe malfunction within the units assembly. You will need to check the following areas for faults:
1. Compressor- Make sure this unit is functioning. if it is not cycling as designed, this will be the culprit. If it is cycling but very hot to the touch when operating, check the condenser coils for debris and clean them if necessary.
2. Compressor start relay - This is the main on/off switch that is attached to the side of the compressor. This relay, when energized by the main control board, starts the compressor. if the relay has failed, it will not start the compressor, thus, rendering the unit inoperable. Pull the relay off and shack it. If it rattles, replace it.
3. Evaporator fan - This is a very important part of the evaporator core. This is the principal air mover of the unit. If this fan fails, the inside freezer and refrigerator will not cool, at all. You will need to remove all the freezer shelves and content to access this unit. It is concealed behind a panel inside the back section of the freezer compartment. Once the concealment panel is removed, you will expose the core and fan. the fan can be tested with a multimeter for proper continuity. You can also jump the terminals with a jumper wire to see if it is still in working order. An external power source will be needed for this test. if the fan fails the test, replace the fan motor.
4. Condenser fan - This is also a very important fan. This fan is mounted near the condenser coils and can fail. You can test it in the same manner as the evaporator fan. replace the condenser fan if it proves to be damaged.
5. Main PCB(Printed Circuit Board)- This is basically your main power controller. This board routes power to all the fans and compressor unit located in the assembly. it also routes power to the lights and ice maker/dispenser, as well. This will be the most expensive repair, in this case. If all the above areas prove to be functional, the main PCB will be the culprit. You can easily locate this board. It is usually mounted on a bracket, near the compressor platform, or behind a concealment panel on the rear of the unit. Once you have gained access, visibly, inspect the board for burn markings at the relay mounts and jumpers. check the entire circuit board for discolorations like brown marks or black burn marks at the plug-in connectors. If this refrigerator is totally dead, this will be the cause.
6. Monitoring thermostats - These are located in each compartment. Replace each thermostat/thermistor if all other check points are ok and functioning as designed.
7. Condenser coils- The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
You will find the culprit in one or all of the areas stated above.
The fridg part is not cooling? Have turned up cooling to 7 whats next is only three years old?
7 is warmer to get colder turn it down to 3
fridge settings work from high number is warm to very cold 1 freezers work opposite with 1 being warm and 6 = -20c
Dec 13, 2017 | Refrigerators
I have a mini fridge from chef mate that does not have a freezer in it. It won't keep temp cold even though it's on highest cold setting. Any answers?
in a fridge the highest or coldest setting is 1 or 0
the bigger the number the warmer the setting
door seal /door not closing properly
have a technician check out the thermostat for correct operation
Dec 10, 2016 | Refrigerators
Refrigerator freezer cools fridge section warm
Yes there should be a defrost thermostat on your refrigerator what is the model number so I know what we're talking about do you see formation of frost on the rear wall of the freezer? Appliance 911 Sea Breeze
I'm here to help you out if you will answer my questions
Sep 08, 2016 | Danby Refrigerators
Hy i have a problem with my fridge freezer , the fridge compartment is acting like a freezer going up to -16
There is normally an adjustment knob inside the fridge, in the back or top to allow you to adjust the coldness. Numbered 1-9.
If you have already adjusted that it would help if I know the type (side by side, freezer on top or below) and the brand. Most side by sides blow some of the air from the freezer side into the fridge side with internal fans and vents. How is the freezer side coldness knob adjusted?
I would set both knobs to 5 and go get yourself a outdoor thermometer to put in each side. It should be about 35 in the fridge and about zero in the freezer. Remember it will be warmer in the top and colder in the bottom of each.
Was the thermostat you replaced in the freezer or fridge?
Feb 02, 2015 | Refrigerators
Refridgerator is not working will not get cold
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacume cleaner stops working when the bag is filled with dust and fibers.
The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air movement from back to front (or visa-versa) of your fridge will slowly (years) prevent how good it cools. The build-up of dust and cobwebs prevents your fridge from cooling (more specifically prevents the heat to disapate from the metal heat disipating fins attached to the metal tubes to be blown off by the fans air). OK! Remedy for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge manufacturers do not provide a dust filter like the vacume cleaner and central air systems manufacturers do. You have to figger out the best way you can clean it. Possibly vacuum with a crevice tool, or use a small brush than vacuum. The extreme would be unplug the fridge ( so you won't get electrocuted) bring a water hose into the kitchen and spray water at cobweb buildup at the bottom fridge, than wet vac the floor then wait 20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air.The fridge
May 30, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge is freezing
There are two things you need to make sure before you declare the fridge at fault. Firstly, make sure that fridge isn't overloaded with items and that any air vents aren't blocked. Give it room to circulate the inside air. That helps it to cool evenly/at all. Next, find the thermostat. This will most likely be inside the top of the door frame when you open the door on newer fridges, or somewhere along the back or side walls. There'll be a setting for the freezer, and a setting for the fridge. The knob might use letters, numbers, or an arrow that says COLDER. Set the knob to slightly warmer, then leave the fridge alone for 24 hours. I highly suggest putting a suitable-type thermometer in the fridge and adjust the temp until it's around 34-38 degrees F. Do NOT allow the fridge to become warmer than 40 degrees. Between 40 and 140 degrees F is the "danger zone" where microbes thrive in food and are much more likely to cause food poisoning. You must never let food sit in the danger zone for more than 4 hours.
If cleaning the fridge and adjusting the thermostat don't work, you'll definitely want to have a refrigeration professional take a look at the fridge. It may as simple as adding coolant or "freon".
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Honeywell Chronotherm III Lowest temperature setting is 45F Any way of getting it lower thanks
If you are successful in setting it lower , you will end up with frozen pipes and large plumbing bills. Since the internal walls of a building can be as much as 20 degrees lower, that the room.
And the location of the thermostat, may be even warmer, that that of the areas where the plumbing is.
Now what is your reason for wanting the thermostat operate at a lower temperature?
Jan 31, 2010 | Honeywell Heating & Cooling
What is the lowest setting on the temp on a Hotpoint Ctf18ga
Hello Dustin,
Typically the lower the Letter or Number is the warmer setting for the freezer or fridge section. If you want to make them colder, move the control setting ONE (1) increment at a time, in any 24 hour time period (up or down) and allow the fridge to adjust before making another change in the settings.
Again, A is warmer than B, and 1 is warmer than 2, and so on. So going to a higher letter or number, will make the unit colder.
Just remember it will take at least 24 hours for your unit to adjust and compensate for the changes, so only make them gradually, so you can tell if you've reached the desired cooling settings for both the fridge and the freezer. Typically, most manufacturers recommend that the starting position be in the middle of the dial and that you adjust them up or down from there.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Refrigerators
Refridgerator not working?
tap on thermostat see if you here fans or compressor
come on or locate defrost timer and advance it
Apr 17, 2009 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
