Question about Givenchy Watches
The gold plating is coming off on the inside of the watch leaving a green mark on the bottom side of my wrist.
    Genius:
  • 1,970 Answers
Mcdevito75 here, The Gold plateing is wearing away die to persperation on your wrist, the only thing to do is have your watch re-plated, approx. $65.00 most jewelers can send your watch out for this re=plateing service.
Posted on Aug 03, 2010
I want to sell a 23k gold electro plated spectrum swiss EB 92107L. pls ao do i go about it.
Take it to a Pawn shop. Is the watch a automatic or quartz. That will be the price defference
Aug 29, 2010 | Android Spectrum Wrist Watch
I have a bulova 18K gold men's wrist watch, which says 3063-5020 AO in a square on the back. Swiss A6 18K. And it is a battery watch, and is still running any idea? of year or price it is very heavy on the...
mcdevito75 here, The movement number tells all, but I would figure the yaer somewhere in the 80"s and value at $250----$350.-- Accutron very collectable watch. Look for a small watch repair shop in your area for more accurate info. Hope this hepls.
Aug 02, 2010 | Accutron Swiss Watch by Bulova 26B44
Remove links, too loose on my wrist
Click on my profile (escapement), then click on Tips and Tricks. There you will find how to add or remove links. Rate me, please.
Mar 31, 2010 | Kenneth Cole Swiss Round Rose Gold Plated...
Adjusting a casio s940db watchband
  • On the inside of the band, locate the links with the arrow etched on them. The arrows mark the removable links.Lay the watch on its side on a flat surface with the arrows pointing downward. Be sure to leave about 1/2 cm of space between the bottom of each removable link and the flat surface. Using a 1/32" flat head jeweller's screw driver (or metric size 1.0), insert the tip of the screw driver into one side of the removable links' pin holes. You will find that the pins have an end that looks like a screw head. This is misleading - press down very firmly on the other end. Press downward firmly to make the pin pop out the other side. Be careful not to lose it.Remove the pin on the other side of the arrow-marked link.Repeat as necessary to remove half the needed links. You will remove the other half from the other side of the band to maintain equal band length.Flip the watch over so the arrows are pointing upward.Align the holes in the remaining links. Insert the rounded edge of one of the pins into the open link hole. The pin will go in without trouble until the top.Holding the pin in place, carefully flip the watch over again and firmly push the pin fully into placing using the flat surface. The pin will snap into place.Repeat for the other half of the band as necessary.
  • Sep 26, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    Casio DBCW150-1 Databank watch (battery change)
    DONT THROW IT AWAY THAT IS A COLLECTORS ITEM... You can get it taken care of at www.casiowatchrepair.com or call them toll free 877.659.0761 and have them take care of it, the watch will be as good as new.
    Jul 06, 2009 | Casio E-DataBank DBCW1501 Wrist Watch
    Rose gold Skagen watch strap changing colour to brassy.
    this answer may sound odd but it happens, Everyone exerts different energy. Skagen bands are usually very tolerant of that but something in the band is having an effect from your skin. which is unlikely but very common in other watches. I believe they use copper in the mix for the rose gold bands, you may want to request a silver or gold band next time.. unfortunately the copper does not react well with your skin.
    Jun 29, 2009 | Skagen 233SSS Wrist Watch
    Info/site for 90 year old Dreadnought watch
    the strap is normally not "cloth", it should be thin gold bracelet type.
    most of them i've seen are from around 1912-1930.
    yours maybe similar to the one below, but it's difficult without seeing the watch.
    http://www.bidorbuy.co.za/item/261641707/Collectable_Vintage_9ct_Gold_Dreadnought_Ladies_Watch.html
    Apr 25, 2017 | Watches
    Eye of Sauron watch eye won't come on
    Check to be sure the batteries that are specific to the special effects (under gold pressure plate) match the correct polarity. The top one should be "-" down and the lower one should be "+" down, but just check to be sure. You can find the polarity noted to the left of the battery and also very small at the edge of each battery slot - just look for a tiny green painted spot with polarity noted.
    To reset the watch, look for the word "RESET" (lower right portion inside case) - notice there are three gold dots centered in green squares. Use either a tweezers or two pins or two small screwdrivers and touch both of the gold round dots simultaneously. That should reset the watch. Check it, if it doesn't work then try it again - two contacts at a time. I think I touched all of them in haste, but I believe it's the two matching gold dots that are the reset. Tweezer separation is almost perfect to rest the watch. That should do the trick. The batteries needed for this watch are SR626SW. Remember to put the black plastic stick on protector over the gold pressure latch that holds the two special effects batteries in place. If it's gone, cut out a piece of electrical tape and cover the gold so it doesn't come in contact with the case back.
    I think that's more info than you needed, but good luck and I hope it works for you. I had to take my watch to the jeweler just to get the case closed - it was a tough one.
    Dec 27, 2007 | Watches
    Watches Logo
    Top Givenchy Watches Experts
    Ansel Alberto
    Ansel Alberto
    Marvin
    Marvin
    Are you a Givenchy Watch Expert? Answer questions, earn points and help others
