Question about Bosch Exxcel WVT3250 Front Load Washer / Dryer
Boschh Exxcel washing maching 0 Fault F16 displayed
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
What does error F:16 indicate?
no one will know without a MAKE and MODEL.
Dec 26, 2015 | Washing Machines
What does E18 fault code mean on a Bosch exxcel 8 washing machine mean?
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Washing Machines
What do's f16 mean on the bosch classixx 6 1200 mean
F16 is a door fault, could be the door is not tightly closed before pressing start, the lock is faulty so the machine is not registering that it is closed or the wiring connection to the door lock is loose.
Apr 10, 2013 | Bosch Washing Machines
I have a Bosch Logixx 8 washing machine showing error code 34. What does this mean?
Same as 'F16', 'F34' stands for 'door lock (fault)' ;-0)
This is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 15, 2011 | Bosch Washing Machines
Bosch Exxcel washing machine started making very loud clicking noises - about 40 minutes into an 80 minute cycle - Spin cycle I think. I turned off and started again from beginning and it has done same...
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of bearings check for tips on this visual link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Aug 19, 2011 | Bosch Exxcel WFX 145S Front Load Washer
Bosch exxcel 1200 express
need more info what point in the wash does it start to display the code
Sep 06, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Code f-3
What should I do when the automatic safety system detects a malfunction?
The programme is interrupted, an audible tone sound and various indicators (if available) point to the
source of the fault.
Fault description table
Small lamp lights up Digital display Audible tone Fault description
“Water tap” “H” and “F” 30 sec “Water inlet fault”
- “P” and “F” 30 sec “Draining fault”
- from “F4” to
“F16” 30 sec “Electrical components fault”
“Water Stop” “A” and “F” 30 sec “Water Stop fault”
Jan 17, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Bosch Exxcel WVT3250 Front Load Washer / Dryer Logo
869 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
