Question about Vacuums
Vacuum cleaner power loss
Vacuum loses power while operating. Just shuts down and will not restart by toggling switch. After a brief (cool down?) period it will start.
Is there a breaker/reset? Does it have a feature that automatically shuts it down when the bag is full?
I can't locate my owner's manual, so am completely in the dark or dirt.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=545672
Generic problem for all Vacuums
Posted by fudpucker on Apr 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Depending on the Brand name and Model # there is what they call Thermal Switches on some of the vacuums that prevent the motor from over heating and possible burn out of the motor If the hose is clogged, the bag is full or the filter is dirty and the air does not flow threw the filter. Any one of the three situations could cause the vac to say “cut out” and stop the motor. So check with your local vac dealer.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 25, 2008
Why has the vacuum cleaner lost power?
If by power loss you mean loss of suction power then I would check and either clean or replace ALL of the filters. Check and clean the rotating brushes and make sure all of the tubes are clear. Almost all suction loss is down to some form of blockage to the air passing through the cleaner and unless the air can pass freely through and exhaust properly, it will not pick up efficiently.
Jan 01, 2016 | Bosch Vacuums
No power what do I do when I stopped and tried ti start again no power . Emptied it and cleaned filter but still not working
All vacuums generate heat and some have automatic cut off switches when the vacuum does overheat. When this happens the manufacturer does not want you to just turn it back on, they want you to know there was a problem and to let it cool down. They often do this with a restart button. Having to press a restart button is supposed to make you think a bit more about the problem and, perhaps, let the motor cool down before restarting the vacuum. The button is often small and red.
Sep 15, 2014 | VAX Appliances Vax X3 Bagless Upright...
It was working fine and them just stopped it is not that old and was not making noises HELP!!
Vacuum cleaners have electric motors in them that require proper airflow to pass over them to keep them cool. Many vacuum cleaners have a thermal (heat) sensitive shut off mechanism built in. This mechanism should prevent the burn out of the motor. If you run a vacuum too long with a clogged hose or clogged filters (especially bagless vacuums) or clogged bags, that is essentially choking the vacuum for air and not allowing it to breath properly. This will cause it to overheat and shut down. Most of the big box store purchased vacuums have very thin wires in the motor windings and can only do this a few times before the motor completely fails. If your vacuum has been shutting down, then cooling off and restarting after about 30 to 45 minutes, then shutting down after only a few minutes of use, your machine is probably clogged up or the filters are compacted.
Jul 05, 2011 | Vacuums
Why does my vacuum cleaner quite working about two minutes into vacuuming? It just shuts off. I have the pet fur picker upper version
Sounds like overheating of motor operating a thermal cut out ..Clean all filters you can run machine with no filters fitted to try if okay first.....
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
This machine has lost suction and the air coming from the motor is very hot - if I left it on, the machine would shut down due to overheating. What is causing the loss of suction?
Hi, Somewhere in the suction lines, starting at the cleaning nozzle up to the canister, there is an obstuction. What is happening is this. The vacuum cleaner motor uses the cool air that it sucks in to cool the electric motor. When the air flow is obstructed, the motor will over heat.
There is another possibility, and that is that the canister is overfilled with dirt, or some type of powder that is clogging air flow. That can cause the same effect.
To handle this, you literally have to get down and dirty.
Go ahead and remove all of the hoses and attachements that you were using when this happened and look for the obstruction. Sometimes on Vacuum cleaners with a blower feature, you can blow the obstruction out using the reverse flow of air. An old coat hanger comes in handy for situations such as this. Sometimes it takes patience to do this. It is one of those things that has happened to every vacuum cleaner I have either owned or repaired.
I hope this is a help to you. Let me know if you have any questions at all,
Best Regards,
Mark
Jan 22, 2011 | Dyson DC05 Cylinder Bagless Canister...
It runs for a couple of minutes shuts off then restarts 30 seconds later runs a couple of minutes and does this over and over
Most vacuum motors are protected from overheating by a thermal switch that resets after cooling down. Check for blockage in the hose,
power head or a full bag that would block cooling air from cooling the motor.
Tom
Oct 22, 2009 | Tristar Vacuums
Nutone central vacuum shuts off after a few minutes running then will restart after motor cools down I cheked motor and vent ports blown out all clean
Sounds like you have an overtemp switch that is tripping and shutting your motor off. Many motors use what they call a 'snap switch" ( looks like a small disk with two wires on it ) to sense motor temp and if that trips, then it will temporarily disable power to the motor until it cools down enough to allow power to be reapplied. If you are sure everything is clean and your motor can rotate freely ( if there is a restriction that limits motor rotation, more current is drawn to drive the motor thru that restriction ..which in turn will cause excessive heat build up and the temp switch to trip) ... Hope that helps!
Aug 13, 2008 | Vacuums
The machine shuts off!! will restart after a few minutes, but shuts right off again...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=560313
The machine shuts off!! Will restart
Posted by mjzimmervt on Apr 30, 2008
Will restart after a few minutes,
Not knowing the brand name or model number of the vacuum, some vacuums have a thermal switch or thermal shut off switch to protect the motor and once the motor gets hot the vacuum will shut off, or the vacuum could very well be clogged and the air is not getting through to the motor to keep it cool. Please check your owner’s manual under the trouble shooting section or cal the factory / manufacturer to see if the can send you an owner’s manual (OM) or you can download the OM from the manufacturer’s website. Next time include the brand name and model #. ? So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Vacuums Logo
330 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
