Question about Sharp VC-H810U VHS VCR
I have a blinking red light issue. I have tried calling sharp and the recommended service people. Can anyone tell me how to fix this myself?
  • Sharp Master
  • 11,800 Answers
Blinking red light signals that the power source is in protected mode becuase another  part has failed and is now shorting the source. You must open the unit and test the power lines coming from the source to find which is down; then follow it till you find the failed part. All of this requires a good experience in electronics - if you don't have it then you can't fix it yourself. Find another shop.
Posted on Aug 03, 2010
Sharp Aquos LC45GX6U & TU-GD10U. The unit doesn't power up, and has a red blinking light from the moment you plug it in. The unit works fine in service mode.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 27, 2015 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
My Sharp Aquos 32 inch has a blinking red light, it's been like that for weeks. A technician came to our house and tried to fix it and he said nothing was wrong. For about 2 hours the TV worked but...
There is obviously something wrong with the set but the tech didn't catch it giving issues so wasn't able to fix it...I"d start by checking the power supply voltages if your able
Dec 10, 2017 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
My glow bouy won't hold a charge.
According to the owner's manual that I have for this swimming pool light (troubleshooting section), a blinking red light is definately a charging issue. The manual recommends that you unplug and replug in the light several times. If the flashing continues, they recommend that the batteries need to be replaced. Unfortunately, you cannot replace the batteries yourself. They specifically state that you cannot open the housing yourself. If you did, you would risk electrocuting yourself AND void any warranties that you have. You will have to take it into the retailer that you got it from or an autorized pool supply/repair shop or replace the whole light.
May 26, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Flashing green power light with no picture
9-if the tv is still under the manufactuer warranty i would definitly give them a call. If it is a Sharp tv I would call the 1-87-BESHARP. I would also try unplugging the tv for at least 2-3 minutes and seeing if the tv will reset itself. Usually what happens with these tv's when the light blinks it locks the tv as a security issue. If the unplug does not help it will more than likely need service to get this fixed for you. The call line hours are M-F 7am-7pm S-S 9-5 and they will be glad to help you from there.
Nov 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos red flashing light tv won't get picture
Nov 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Oct 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp FO 6700 Plain Paper Laser Fax
No there is no configuration page. The red blinking light means you have no paper under your blue tray or the paper empty sensor is broke. To identify the noise open the lid then close it, if you hear the noise while the fax is warming up then most likely you have a bad gear that meshes with the fuser drive gear, although it could also be the toner or drum. If it's not the toner or drum I stongly recommend a service technician , he should be able to provide an exit tray.
Oct 05, 2008 | Sharp FO 6700 Plain Paper Laser Fax
Battery light blinking red while charging
My camera charger was blinking red and the battery would not charge. I called Casio customer service and they offered to send one out! They did ask when the camera was purchased and I told them it was just a couple of months ago when it was actually more than a year. Casio 1-800-435-7732
Feb 28, 2008 | Casio Exilim EX-Z750 Digital Camera
Blinking red light
Same problem with TH-42PZ700U. Took the plug out of the powerstrip and stuck it in the wall outlet and no fix. I will call Panasonic tomorrow. Thinking it might be a heat issue, cause it has been working again after it cools down for 20 mins. Only had this unit since 10/4/07.
Sep 08, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Sharp VC-H810U VHS VCR Logo
200 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
