Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Model 917.276180/42"/20hp Having trouble starting! The key turns but nothing happens immediately. Next I notice smoke coming from an electrical part on the engines right side which this part is connected to a red cable. (It looks like a small black oil filter but I know its electrical) Will start slowly after waiting approx 30 mins after making first attempt by playing with choke.
  • 45 Answers
That is yor starter and in probably to tight to the gear or you need a new starter which costs about 100 dollars
Posted on Sep 09, 2010
I have a 95 Dodge stratus..2.4 L. The past week it was having trouble starting. After turning key off then on..3..sometimes 4.. it would start right up. Next morning had to do same thing. Yesterday I took...
Yes, it has to do with the ignition switch. but just as possible could be a battery connection from the battery to the switch. So, sometimes turning key to ON causes no dash lights or warning lights to come on?
That sounds like a bad switch, or more likely, a bad battery connection or a bad connection between the battery and the switch. First thing to do is check the charge of the battery, it must register at least 12 volts. 12.6 volts is the ideal for a good and fully charged battery. Clean and tighten all battery connections.
Sometimes when you have a poor connection, from looseness to corrosion, and you turn key and see all warning lights and gauges come on, and then turn key to start and everything goes black...that can happen because the power surge causes the bad connection to come apart. So check for loose or corroded connections.
Mar 02, 2018 | Dodge Cars & Trucks
Turned key once, it tried to start but didn't, turned key again but nothing happens except smoking under hood. what is going on with my car?
If you are having smoke coming from under the hood you may have an electrical issue. Check battery and cables for no corrossion as well as tight connections. You may also have a high amperage draw from the starter motor causing excess heat in the wiring producing smoke and may have to have the starter replaced.
Jun 21, 2015 | 2004 Chevrolet Chevrolet Impala
Smoking from under hood
A leak of some fluid, probably oil, dripping onto the exhaust. This smells terrible, and it only needs a drop or two.
Jan 22, 2014 | Honda Cars & Trucks
I have a Jacuzzi J340 Hot Tub. I am having trouble with the heating. When the pump is on, the water circulates just fine. once the heater kicks on, it runs for about 10 seconds, then clicks to OH, and...
make sure the heating element isnt touching the casing inside the heating tube. if its an indoor tub, make sure the filtration cycles are not set to constant. constant filter cycles on an indoor tub will generate residual heat from the circ pump running 24/7, causing tub to heat past 104 degrees
Sep 15, 2013 | Jacuzzi Pool & Spa
2009 VW Routan se will not start. Battery is good. All lights etc come on and work. Six months ago i had the key replaced due to same problem. Dealer said the key was no good and was not making a...
This is an old post...but it happened to me today. Electrical works, but car will not start. I disconnected the battery cables (both) and touched the positive cable to teh ground cable hopefully trying to discharge the codes. Left it alone for a few minutes and reconnected the cables. The car started immediately?? Yes...I will now keep a 10mm wrench in the car for next time.
May 15, 2011 | 2009 Volkswagen Routan
This morning when I attempted to start my 2006 Hummer H3, nothing happened. I thought I may have a dead battery but the lights and radio work fine. I then noticed the Passlock security lock light was on...
Hello:Try this procedure: turn key on, turn to start, let key come back to on wait ten minutes, turn key off wait 10 seconds turn key back on wait 10 minutes. turn key off wait 10 seconds turn key back on wait 10 minutes turn key off wait 10 seconds NOW try and start. In addition you might try tapping on switch assembly while trying to start. There is not any way to disable passlock. You might try having the engine control system codes read
Feb 01, 2011 | 2006 Hummer H3
I have a 1996 eldorado, after changing oil at jlube i started the car and noticed ac on and temperature set as hot as possible,i took off and immediately smoke came out of vents and now theres no air...
there is nothing that is going to break by having the AC on and then turning up the temperature all the way except a little worse fuel mileage. Keep in mind that your AC comes on during the defrost mode to help dry the air inside your car so your windows dont fog up. If there is no air movement then it sounds like the blower fan decided it was time to quit. It just happened now instead of the middle of winter or the day you needed the defroster--(defogger)
Apr 27, 2009 | 1994 Cadillac Eldorado
Electrical Problems
Do not leave the car in the garage without the battery disconnected until you locate the source of the smoke, the best tool to find the smoke's source is your nose, smell the area around the source of the smoke, if you smell a really nauseating smell you found it, then look for signs of burnt wires or burnt components, also look for any oil that may have caused the smoke, but I doubt that was the source, this sounds electrical. I know of no problems for your car that would cause this, so most likely it is not a common problem.
Oct 19, 2008 | 2003 Mazda Tribute
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
175 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
