Question about Samsung WF337AA Front Load Washer
Samsung Front Load VRT - nd error
My machine is ony 2 MONTHS old and I have already had a tech out here (needs parts which take which seems like forever with a family of 6) I get the nd error. The tech cleaned out the hoses to the pump and replaced the pump, which got the machine working while I wait for parts.. It is 4 DAYS later, no parts yet and now the nd error is there again. How hard is it to clean out the pump hoses myself?. I have been very diligent in checking pockets now that I know there is nothing but the pump hoses to catch anything in the washer. Am I correct that there is no filter to catch this stuff?
Thanks,
  • Anonymous Mar 30, 2009
    i have the same problem but everytime i get somebody to my house to fix it it starts acting up after the person leaves.
    Genius:
  • 1,073 Answers
Where did you buy it from, call the store and tell them if they cannot get you the proper service to replace it
Posted on Apr 25, 2008
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Oct 24, 2015 | Samsung 3.9 Cu. Ft. VRT Steam and Power...
Samsung vrt nd or nb error code
ND is not draining, the washer probably has water in it and won't open. In which case you need to open the little tiny panel on the front of the washer and pull out the little hose and drain the washer and then clean our the filter next to the hose. NB means not balanced and the clothes have become unbalanced, move the clothes around and start it back up. If it happens a lot the washer is not on even ground and needs to be leveled.
Feb 18, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung vrt front load washer
You should be getting error codes. Here's a link to Samsung's online help (it also provides a list of error codes and what they mean): http://www.samsung.com/us/support/owners/product/WF331ANW/XAA
Hope this helps.
Aug 16, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung vrt front loader turns on but shorts out (I think) when I press any other brtton
It seems like grounded or loose wire or heating element or control board grounded
Best way is to do step by step troubleshooting procedure to find problem
Dec 10, 2013 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung WF209ANW front load washer -- ND error code. I cleaned debris filter and all hoses, however it still will not drain. How can I tell if the drain pump needs to be replaced? Is there a diagnostic...
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Sep 25, 2011 | Samsung WF328AA Front Load Washer
My samsung vrt front loader will not drain or spin and showing nd code
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2010 | Samsung Washing Machines
Samsung WF337AA Front Load Washer Logo
1,235 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
