Question about Panasonic PT L511XU Multimedia Projector
We changed the laptop that is connected to our PT-L555U LCD projector. The RGB connection on the first laptop projects as a BLUE screen, which is what we want. However, we can only get a green color sceen with the new laptop on RGB conneciton (video is fine). Do you have any suggestions on how to change the RGB connection to a blue screen?
  • 81 Answers
Please adjust the VGA cable properly
Make sure the cable is properly fitted
Posted on Aug 03, 2010
Panasonic PT LB50NTU - LCD projector need to connect to my IMAC - what cord do I need?
The Panasonic projector PT-LB50NTU or E have two type of data inputs.
One is RGB or VGA cable and second is VIDEO cable. If your IMAC have video or vga output than you can connect.
Two type of cables witch are using with projector good_help_0.jpggood_help_1.jpg
Jan 14, 2011 | Panasonic PT-LB50U Multimedia Projector
Pt-45lc12
It looks like a problem with a tube (projector light) I suspect the green one. Pay attention to flickering on the lights and post me the results.
Nov 01, 2007 | Panasonic PT-45LC12 45" Rear Projection...
My Canon LV-5210 displays no image for my computer. It has worked fine in the past. And it did not work a couple days ago and then it worked OK yesterday when we accidentently pushed the Input buttom. But...
If your projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F2 or F2 once: The laptop screen only
* Press Fn / F2 or F2 twice: The projector port only
* Press Fn / F7 or F2 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
this should help you :)
Aug 26, 2010 | Canon LV-5210 Multimedia Projector
I have conected my laptop to a projector using a rgb connection and get the bootup picture from my laptop onto the screen then it dissapears and just shows a blue projected screen. I have tried using Fn...
try to restart your laptop into safe mode with still the projector connected. notice if your safe mode desktop appears projected as exactly as your laptop's desktop screen. if so, you only need to further configure your display settings.
Dec 29, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Color shift blue tint
This could also be a setting. If you are using component video as a connection, make sure that the unit is set for RGB if coming from a laptop or other computer system. If the projector is set to YPrPb, the picture will look purple or bluish as you describe. Change the setting to RGB and all should be well.
Dan
Oct 26, 2009 | Hitachi CP-X1250 Multimedia Projector
Projector displaying yellow tint in center of screen.
The yellow tint is probably coming from the lens. It could be that the glass is tempered or possibly just needs to be cleaned.
Jul 24, 2009 | Sanyo PLV 60HT Multimedia Projector
I cannot ger the projector to project the image on the laptop. I have held down the Fn Key and F8 to no avail
connect the projector to your laptop and restart the computer in that way it would recognize the presence of your projector... ;)
Nov 18, 2007 | Office Equipment & Supplies
Panasonic PT L511XU Multimedia Projector Logo
164 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
