Question about GE (PSS26MSRSS) Side by Side Refrigerator
Hi i have ge fridge model gss22wgmd the freezer is cold and icing up and not defrosting what could be the problem
MNTECH
  • 1543 Answers
SOURCE: I have a GE GSS25WGMD BB Fridge. I have already
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Posted on Jun 09, 2009
  • 1122 Answers
SOURCE: Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Posted on Nov 13, 2008
  • 111 Answers
SOURCE: GE side by side fridge TFX22JR not staying cold
You need to unplug the unit and check continuity with a meter across the defrost heater/s. If they are open, that's your problem. The defrost termination thermostat HAS to be below 20 degrees (varies model to model) to close. If at room temp it will read open. Doubtful it is your defrost timer.
Posted on Dec 16, 2008
  • 163 Answers
SOURCE: Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Posted on Mar 09, 2009
heatman101
  • 43501 Answers
SOURCE: My regrigerator (GE Profile) is
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 17, 2010
Testimonial: "This advice is very good. Based on this I think I know what my problem is. I will try these suggestions. "
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
Model # - CTX16CPCR LF752813 - Serial number Its leaking water from the freezer into the fridge...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | GE PTS22SCRBS Top Freezer Refrigerator...
Top shelf of freezer and ice maker not cold and top shelf of fridge not cold. everything else on bottom shelves is frozen and cold .GE model GSS22JEMA
heatman101
Sep 17, 2010 | GE GSS22JEM Side by Side Refrigerator
My regrigerator (GE Profile) is not cold on the fridge side, but ok on the freezer side. I found ice buildup in the freezer so I defrosted and dryed it completely, cleaned it- including coils...
heatman101
Sep 16, 2010 | GE Refrigerators
GE Monogram Built In Fridge-freezer is not cold enough, but ice is ok...refrigerator is too cold no matter the setting. Someone suggested vacuuming filter above the fridge. Would this work?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Feb 23, 2010 | Refrigerators
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
GE Side By Side top portion of fridge and freezer not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Nov 30, 2008 | GE GTH18KBR Top Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
187 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
