My whirlpool calypso gets a co sl - Washing Machines
    President:
  • 1,554 Answers
“SL” is displayed if suds are detected but the unit is unable to clean it out. This may indicate a bad pump, an extra heavy load, excessive detergent or excessive suds. Press STOP/CANCEL to clear the display then run the machine with few number of clothing and do not use detergent. This is to verify if overloading or suds are indeed causing the problem or not. The problem is a bad pump if the fault code still flashes.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 03, 2010
2 Suggested Answers
SOURCE: Whirlpool Calypso - replaced pump/motor, but still
So here's my solution... Remove the new pump/motor combo. Go to "Appliance Center" and pick out a nice new Maytag and have it delivered the next day. Have them haul the POS Calypso away and sell the new pump. Let me know it you need a new pump....
Posted on May 04, 2009
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Code SL or 5L?
It is Code SL which means Suds Lock. Either you have too much soap suds for it to drain properly or Your drain pump is clogged and not spinning properly. Try running it through a rinse and spin cycle and if you still get a code (SL or Ld) then you will probably need to replace your drain pump.
Oct 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Keep getting the SL error code. what can we do to fix problem?
Suds lock. Turbidity sensors have detected excessive suds. Repair Manual page 48
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops and give an SL error code
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer failure and will need to be replaced.
Please rate my help++++Thanks for using FIXYA
Nov 28, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso - replaced pump/motor, but still get incomplete spin cycle with 'ob' and 'sl' errors. Never gets up any speed during spin cycle. What else might this be?
May 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
GETTING SL error
Suds lock, use he soap and be sure to use the cup at mark 1 or less. If you have a water softener use a 1/4 less.
Aug 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso displaying SL or5L messages, did you get it fixed?
I see at least 2 of these a week. 9 out of 10 times, it's the pump. If the u-joint is bad, it will put strain on the motor causing it to think it's overloaded as well.
Jul 12, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Keep getting SL error code
Sep 27, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
