Question about Dryers
I have a Kenmore Series 80 electrical dryer. It isn't getting hot/drying. I had this problem 4 years ago and the tech who fixed it said i shouldn't have the same problem for 10 years. Sounds like the heating element, what do you think.
  • Dryers Master
  • 1,606 Answers
The problem most likely is the thermal cut-off . This is the small t-stat lookin piece , located on the upper portion of the element housing . You can unplug the dryer , remove the 2 wires , connect them togather , plug the dryer back in , to test . If the dryer then heats , replace the thermal cut-off . If still no heat , then possible bad element . Also see
http://www.fixya.com/support/r4580247-whirlpool_or_kenmore_dryer_not_heat
Posted on Aug 03, 2010
Dryer warms..... but not enough heat to dry...about 10 years old 80 series Kenmore electric dryer
Probably has a broken heating coil...as the temperature goes up it expands and moves from natural position of touching....that would give the false indication of continuity in the coil when it cools back down and touches again. Visually inspect coil.
Nov 02, 2013 | Kenmore 800 7982 Dryer
The dryer isn't getting hot
Here's a good troubleshooting article on them:
http://www.ehow.com/way_5389575_troubleshooting-kenmore-series-dryer.html
Keep in mind, it is an older dryer, but that series is known for being really good. If the article doesn't check out, I would suggest calling in a technician as it's possible something got damaged in the move/
Dec 31, 2012 | Kenmore Dryers
Dryer stopped working as it was drying, was real hot and will not start now. Kenmore 80 series electric
Problem common with blocked vent, need to check house vent...dryer has blown the thermal fuse. found behind the back panel small white fuse(usual two blue wires)....clear the vent and replaced the fuse. run on air dry first to check vent, should feel close to a hair dryer on low.
Jun 10, 2009 | Kenmore Dryers
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore dryer only heats on delicate
I am not familiar with this particular dryer but most of the Kenmore family use different thermostats for different temperature. They are usually located in the rear and are clustered on the blower housing. Take the two wires off one thermostat at a time and test. It should be closed when cold if not replace it (Usually around $15 each) You probably have a very dangerous clogged exhaust. This will cause thermostats to fail. and can cause a fire. CLEAN It out and dont use flexible plastic duct pipe. The other cause of thermostat failure is if the washer doesn't spin properly and the clothes are too wet when dried. A properly operating dryer will not take much longer than 45 minutes max to dry a load.
Jun 14, 2008 | Dryers
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
