Question about Ingersoll Rand Ingersoll - Rand Ir 117 Long Barrel Air Hammer
How to find a replacement spring for the modell 117 air hammer
I need to replace overload switch in friedrich air conditioning model CP15G10
The part number is a Klixon MRA12107-117 this can be bought at any supply house
May 30, 2014 | Friedrich KStar KQ06J10 Air Conditioner
How do you fix stuck valves on a 86 Suzuki gs450l
Instructions
    • 1 Disassemble your engine down to where you will have access to the valve spring. You will need to remove the cylinder head cover, the rocker arms and the push rods. You will also need to remove the spark plugs.
    • 2 pixel.gif Next turn on your air compressor and regulate the air 60-90 psi, turn the crankshaft until the cylinder you are replacing valve seals on is on top dead center. Screw the compression gauge hose into the spark plug hole, attach the air compressor hose, your cylinder is now pressurized.
      The valves will stay in the closed position as long as the air pressure is holding it up.
    • 3 pixel.gif Using the valve spring tool, compress the valve spring and remove the valve keepers with a magnet. These may be stuck to the valve spring retainer and a little bump with the palm of your hand or a small hammer will jar it loose. Pack towels around the area so you won't lose the keepers into the engine. Remove the spring.
    • 4 Remove the old valve seal with pliers or screwdrivers and replace with a new seal. Reverse procedure to reassemble engine, use the magnet when installing keepers and after removing valve spring compressor tap the top of the valve lightly with a hammer to seat the keepers.
Jan 13, 2013 | Motorcycles
Need instructions on replacing drivers side door hinge pins and bushings
  • 1. Place masking tape on the inside edges of the door, on both the inside and outside of the door. 2. Remove the door spring by using a door spring removal tool. Insert the tool into the door spring, turn the knob with a screwdriver to compress the spring, then pull out the tool. 3. Set a 5-gallon bucket under the door. This will help support the weight of the door. 4.Place a nail punch under the hinge pin, and strike it with a hammer. Repeat this until the hinge pin begins to come out of the hinge. 5.Place the end of a flat-head screwdriver under the top of the hinge pin, then strike the screwdriver with the hammer to force the hinge pin out of the hinge. 6. Place the bushing on top of the new door hinge pin, and tap it into place with the hammer. 7. Insert the new hinge pin into the hinge. Tap on the hinge pin with the hammer and nail punch to force the pin into the hinge. 8. Insert the hinge spring back into the door, and release the tension on the spring removal tool. 9. Spray the door hinge with a lubricating spray or apply grease.
    I know there are a few directions but it is fairly easy to do. If you have access to an air hammer and a compressor you can use this in place of a manual hammer to make the process a bit easier.
    Hope this helps.
  • Mar 10, 2011 | GMC Sierra 2500HD Cars & Trucks
    The trigger does not work
    the trigger valve is either ****, the o ring worn or the spring broken, remove trigger valve from the bottom of the handle, usually by removing the air intake
    May 10, 2010 | Ingersoll Rand Ingersoll - Rand Ir 117...
    Check tiny allen head grub screw has not loosened on bottom trigger button and is catching on housing, otherwise one of the o-rings is missing off trigger plunger or piston. Carefull of spring behind trigger button when loosening allen grub screw. You will find the plunger behind trigger button.
    Apr 22, 2010 | Ingersoll Rand Ingersoll - Rand Ir 117...
    Winchester model 88. with the trigger assembly
    Less Than Perfect
    The Model 88 had its faults. The trigger moves with the lever and the resulting linkage to the sear results in a rather spongy, creepy trigger break. If you want to see your gunsmith turn pale, waltz into the shop with an M88 and ask for a crisp three-pound trigger.
    If you already have taken the gun apart, don't be afraid to hone the parts on a stone , keep them flat, you don't want anything rounded off. Especially the sear. I found that quote up top from a winchester sight,
    Feb 22, 2010 | Optics
    Ibm 6400
    This is a easy problem... Have any question call 972-907-9771 x311
    51e9bbd.jpg ATTENTION Hammer springs and hammer tips are fragile. Do not touch the hammer springs or tips. Handle hammer springs by the
    thick mounting base only. Apply pressure only to the mounting base.
    NOTE: Replace a hammer spring assembly only if there is visible damage or broken parts can be seen in the assembly.
    5. Remove the mounting screws from the old hammer spring assembly. (See Figure 18, page 367.)
    6. Handling the hammer spring assembly by the mounting base only, gently pry the old hammer spring assembly off its
    mounting pins. (See Figure 18, page 367.)
    7. Inspect the hammer bank and the old hammer spring assembly:
    a. If there is ink on the hammer bank mounting surface, the hammer spring assembly mounting surface, or the hammer
    spring neck or tines, reinstall the old hammer spring assembly and replace the shuttle frame assembly (page 405).
    b. If the old hammer spring assembly and the hammer bank are free of ink, install the new hammer spring assembly
    Installation
    1. Using a clean dry cloth, wipe the hammer spring mounting surface on the hammer bank. Make sure the cloth does not
    leave lint on the hammer bank.
    NOTE: Replace a hammer spring assembly only if there is visible damage or you see broken parts in the assembly.
    2. Handling it by the mounting base only, remove the new hammer spring assembly and mounting screws from the box.
    3. Handling the hammer spring assembly by the mounting base only, carefully position it on the hammer bank mounting pins.
    then gently press the mounting base down against the alignment pins. (See Figure 19, page 369.)
    4. Continue pressing down on the mounting base of the the new hammer spring assembly as you install the mounting screws
    from the replacement kit. Using a Torx T-10 bit adapter, torque each screw to 14 inch-pounds (1.58 N•m). Tighten the
    center screw(s) first. (See Figure 19, page 369.)
    NOTE: Use the 1-30 inch-pound Torque Screwdriver, IBM part number 16F1661.
    5. Install the hammer bank cover assembly (page 354).
    6. Install the shuttle frame assembly (page 405).
    7. Install the ribbon and load paper.
    ATTENTION Do not attempt to adjust or “tweak” hammer springs.
    8. Run an operator print test and check print quality (page 223):
    a. If print quality is acceptable, return the printer to normal operation (page 339).
    b. If print quality is still degraded, replace the shuttle frame assembly (page 405).
    Sep 10, 2009 | IBM 6400 Matrix Printer
    Ingersoll Rand Ingersoll - Rand Ir 117 Long Barrel Air Hammer Logo
    Top Ingersoll Rand Air Tools & Compressors Experts
    elunsford
    Eddie Tucker
    Level 1 Expert
    John Trevino
    Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
