Question about Jenn-Air Grilling
I have a 4 burner Jenn-Air barbecue grill. I cannot find a model number to order replacement parts. Is there parts dealer near my zip code 19087? Thanks,
    Brigadier General:
  • 3,513 Answers
Hi
Try to find the model number inside the right door.
Please check this link bellow for the official site of Jenn air.You can contact the customer support for your query.
http://www.jennair.com/flash.cmd?/#/page/customerservice
http://livesupport.maybenow.com/Jenn-Air
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 03, 2010
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Do Jenn-Air have recommended suppliers? I have a Jenn-Air Gas Grill Model 720-0163 and need burners.
Appliance Factory Parts http://www.appliancefactoryparts.com/ is a good place to start. They carry parts for just about all makes and model grills. If you can't find what you need under Jenn Air, try looking under NEX Grill. Actually, they are the manufacturer of the Jenn Air Gas Grill.
Hope this helps you. Please let me know. Happy Grilling.
Jun 26, 2011 | Grilling
I am in the process of replacing my burners on a Jenn Air model #7200063LP. The burners appear to slide into the gas feed tube on the front part of the grill and attached to the back part of the grill with...
Yes, there really is enough space. Remove the cotter pin(s) and while lifting up the end of the burner farthest from you, pull the burner up and out.
To replace the burners, do the above in reverse. Just be sure the burner tube slides over the burner orifice, properly.
Hope this helped you change the burners and Happy Grilling!!
Jun 06, 2011 | Jenn-Air Grilling
My Jenn-Air grill model 720-0336 when you lite one burner it will lite but with low height in flame and as you tun on another flames go to 1/8 inch high as you turn on the last burner than go out. This...
It could be a couple of things. First you could be low on propane or natural gas depending on what you use. The second thing is that over time the little holes in the burners clog. You can poke them clean with a toothpick. Or if they are rusted you will need new ones which you can find from an appliance parts dealer. If they don't have your part start looking on ebay because your grill is discontinued. Jenn-Air might be able to help you find the parts if you can get in touch with a customer service rep.
Sep 29, 2010 | Jenn-Air Grilling
Yellow flame
You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
Douglas
Jun 06, 2010 | Char-Broil CharBroil Master Flame Gas...
Where can you find spare parts?
For information about replacement parts, or warranty service call our Customer Service Team at 1-800-752-3085. If we can't answer your call, you can leave a detailed message allowing us to research your inquiry and respond with an answer. Please include a description of your grill (make, model, and number of burners), an order number or how long ago you purchased it, and your zip code so we can determine if there is a store in your area.
You may also call your local Barbeques Galore store for replacement parts and warranty service. Click here to find a store near you.
By Email Note: if you need to email photos to Barbeques Galore, please wait for Customer Service to reply to your initial email before sending digital photos. Thank you.
CustomerService@BBQGalore.com
By Mail Barbeques Galore
2173 Salk Avenue
Suite 150
Carlsbad, CA 92008
Dec 12, 2009 | Barbeques Galore Cook-On 2-Burner 167777...
Jenn-Air #720-0163 won't start
If there is no gas coming out of ANY burner - your REGULATOR has failed.
PLEASE CLICK HERE to see the replacement part and ordering info. (near bottom of page)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question!!
Apr 29, 2009 | Grilling
Jenn air grill
You should test the wiring to see if there is any short that is causing the overheating.
If one knob only is getting hot, then the knob is probably faulty and need to be replaced.
I the all knobs are overheating because of heat coming from the grill, then is a bad heat insulation problem, better to call the service number listed on the owner manual and discuss the problem with Jenn Air in this case.
Here you find replacement parts for your model, in case you need to replace a knob.
Sep 16, 2008 | Grilling
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn air propane grill conversion
It is inconceivable to me that large manufacturers like Jenn-Air and Nexgrill can jointly make and sell an expensive grill and then completely abandon the consumer. I purchased an Jenn-Air 740-0142 LPG and like so many wanted to convert to nautural gas which requires a larger gas orifice. I spent a month on the internet and phone calling Jenn-Air and finally Nexgrill who actually manufactured the unit in China. The Jenn-Air and Nexgrill serial numbers are the same. the 740 prefix is LPG and the 750 prefix is natural gas. After three calls to Nexgrill I found a manager who actually acknowledged making Jenn-Air but declined selling me parts for it as I believe they have product liability concerns. I call back as a Nexgrill owner and finally ordered natural gas orifices at $10.00 each. The shipment never showed up. Calling back again I was told that they really didnt really have any orifices in stock but could sell me the entire replacement gas valve for $28.00 which I purchased. The valves actually arrived on the shipping receipt was from The Grill Services in City of Industry 909-718-6128 www.grillservices.com . Part number 750-0141/142/593/594.
Forget about pirates in Somalia... we have them right here. Shame on you Jenn-Air and Nextgrill.
Mar 12, 2008 | Grilling
Grilling Logo
15 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Fred Harvey
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
