Question about Brother Office Equipment & Supplies
HL-1440 We had an unexpected power outage and now the drum light blinks then all 4 lights blink. I try to push the reset button and nothing. It was working fine prior to the outage. It it just a local printer
  • 268 Answers
Try this solution.
* Turn your printer off.
* Hold in the circular button on the front panel of your printer.
* Turn your printer back on.
* When the drum light is lit by itself let go of the button.
* Hold in the circular button on the front panel again.
Once the Alarm light comes on, let go of the button.
Your printer should now be reset.
Hope this help you.
Posted on Aug 03, 2010
On HL 1440 Laser Printer, ready and alarm lights (red) on control panel are lit.
Don't fiddle with it you'll just mess with it more take it in and see what they can do if not i suggest you by a new one.
Nov 28, 2011 | Brother HL 1440 Laser Printer
Drum light was blinking. I reset my Brother HL 5240 printer and it still won't print.
Try to reset the Drum.
Open toner door and hold down the go button until all lights are on, let go of button, close door, push go button. Resets drum counter to 100%.
May 04, 2011 | Office Equipment & Supplies
Why does the drum light blink on my brother hl-2140
The blinking indicates that the drum unit is near the end of it's life. It will shut down soon and you will lose the ability to print until it is changed or reset.
To reset the drum counter. Press and hold down the white button (shown as blue in the image below) for about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the button.
Nov 18, 2009 | Brother HL 2140 Laser Printer
How do I reset the printer? I had to change my
You have to open the front door and press the go button until the lights flash, that resets the drum. The instructions are packed with a Brother drum...
Aug 11, 2009 | Brother HL 1440 Laser Printer
Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Reset the drum counter only when you replaced the drum unit with a new one.
Aug 03, 2009 | Brother HL-2040 Laser Printer
Power went out and back on; now printer won't print
I had the same problem after a resent power outage. Here's what fixed mine.
Turn the power switch off.
Wait a 15-20 seconds
While holding the button on the front panel down turn the power switch on.
After the drum light comes on release the button wait then press the button again.
Turn the machine off then back on again and you should be back in business.
To prevent the problem in the future if you are not using the printer turn it off and if the power goes off while printing get the printer turned off before the power comes back.
Oct 14, 2008 | Brother HL 1440 Laser Printer
Alarm light only, doesn't print at all
Chances are that you have a piece of paper stuck in the printer. Open the rear door and check there first. If that's not it, remove the toner/drum assembly and check behind that. The other place to check is between the drum unit and the toner cartridge.
Sep 14, 2008 | Brother HL 1440 Laser Printer
HL-1440 Blinking lights
Mine had the 4 led's blinking alternating with the drum. I held down the button on the front till all lights were on steady and pressed the off switch on the left (while holding the front button down). After powering back up all was well again.
Apr 29, 2008 | Brother HL 1440 Laser Printer
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2040 Laser Printer
175 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
