Question about Craftsman Garden
Old craftsman pull cord mower starts and then stops immediately. changed air filter, spark plug, and put new gas in , fuel filter seems clean.
  • 755 Answers
Your carbs main jet is blocked most likely.
Take the carb bowl off and look at the bolt near the top of the threads.
You should see a very very small hole. If you can see through it you need to clean it with a fine strand of metal wire.
Also work the float up and down to make sure it isnt stuck or unable to flow when the float hangs free.
Put it back together and try it out!
Good luck and be careful!
Posted on Aug 03, 2010
Craftsman 675 series 190 cc lawn mower Wont start
Take air cleaner off. Shoot some spray carburetor cleaner in the carburetor and try to start Try this a few times to see if the engine will fire.. If it fires or starts then there is a fuel delivery problem. Could be a dirty fuel filter, bad (stale) gas, a dirty carburetor. If it does not start with the carb cleaner, check the spark plug. It may be fouled. Check for spark - take plug out of head. with the plug attached to plug wire, hold plug with a pair of insulated pliers, and touch outside of plug where the threads are to the engine, while some one pulls on the start cord. You should get a bluish spark. If you get a weak spark use a new plug and try again. There should be a bluish spark. Make sure you hold the plug against the engine making good contact. If no spark at all, could a bad magneto.
Getting back to the carburetor. If you think the gas in the tank is stale, drain it out and put fresh gas in the tank. Change the gas filter.
The arburator may be cleaned by pouring a 1/2 can of fuel system cleaner in the gas tank and spraying the spray cleaner down the carburetor throat.
Jun 03, 2014 | Garden
Not getting any spark
Clean the Plug and replace the Seafoam gas with fresh. Althiough the Seafoam is a cleaning agent, it cuts back on the gasolines octane and it can slightly foul plugs.
Aug 07, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Mower begins then stops before in use
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Mine did this.
It means that either not enough gas is getting into the engine. The gas you pump in when you prime is enough to start the engine but not to keep it going.
There could be several things that cause this.
1. Old fuel:
Solution: Replace the fuel. Dump out the old stuff. If it is a year old it won;t work.
2. A dirty carburetor:
Solution: Clean the carburetor.
Easy carb clean:
Pull the bowl off and use carb cleaning solution to clean it. (you can buy carb cleaning solution a Wal-Mart in the automotive section. I have also heard acetone will work but I have not tried it.) Make sure not to loose the little parts like the pin.
Better carb clean:
pull the carb off the machine and clean each part with carb cleaner. There is a youtube video someone else posted on how to do this.
3. Your gas/air flow is not adjusted properly.
To check:
Pull off or out the air filter. Try to start it.
Solution:
If the machine runs longer there are two options: The air filter is dirty so replace it, or the air flow is not adjusted proberly. There should be a screw like thing sometimes called the "main jet" that you turn to adjust the air flow. It is on the carburetor side or bottom.
If the machine dies faster or won't start there is probably too much air flow and by removing the filter you added more air. Adjust the "Main Jet" as above.
Apr 15, 2009 | Craftsman 10.5 Hp 33" Commercial Cutting...
Yard-Man Mower model 418D401 doesn't start
Need to remove carberator bowl nut and bowl and activate float to smell new gas coming thru,stuck mostlikey due to storage.
Please rate. Thanks. jj505
Mar 29, 2009 | Garden
My lawn mower doesn't start
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Dec 22, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
90 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
