Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My Cabrio no longer adjusts water level according to load size. It fills to the max each time. How to fix?
  • 171 Answers
Problem most probably in clogged pressure hose leading to pressure switch or bad pressure/level switch itself.  you can try cleaning the hose by simply blowing into it after disconnecting it from the pressure switch.  a simple fix but if clogged, it usually works.
Posted on Aug 03, 2010
Testimonial: "Thanks. Will try that."
  • fygraphics Aug 09, 2010
    I thought I'd let you know how I resolved the problem. I simply unplugged the washer and then plugged it back in. I wondered if treating it like a computer might work, and, it did! Works as it should again. Thanks again for the input.
New Samsung Top Loader13kg WA13J571 Wobble Techn,used for the 1st time-water level 1(LOW)still filled the WHOLE machine with water.Bigger load on level5(FULL)never stopped filling with water.
use the features fuzzy logic, u only need to power on and start on the machine when u hve fill in the tub with cloths and soap. water will fill in according to the load filled.
Sep 08, 2017 | Samsung Washing Machines
We just bought the washer and now it will stay on for 5 mins then all buttons blink and it says LF
LF stands for long fill,if it takes longer than a preset time by the machine it will go to LF,check water fill hoses for kinks,plugging that will slow down water fill time
Sep 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Wash machine - DST10146P Problem - After switch on and without any load in the drum, the kgMODE indicator appear, and the level load indicator starts blink the 10% levels from the mini to the MAX. The LED...
THIS MAY be your defective part!
BE VERY careful handling this switch because it's quite delicate!
1885374 "PRESSURE SWITCH" $89.68
Use THIS LINK:
http://spares.bigwarehouse.com.au/index.php?cPath=64618_64688_109010
These YOUTUBE video MAY help you!
Here is another YOUTUBE that discusses "Pressure Switches"... and that MAY be your problem. KNOW this is general information and not specific to your Hoover!
Diagnosing Washing Machine Pressure Switch Problems
How to Resolve Pressure Switch Problems in Washing Machine
Hoover and Candy Washing Machine Error Codes
TROUBLESHOOTING Link:
Dynamic Model No DST10146P 80 Product Code 31003253
Another snip-it:
..."Kg MODE Indicator". On Cotton and Synthetic cycles, during the first 4 minutes of the cycle the intelligent sensor will weigh the laundry and adjust the cycle time, water and electricity consumption accordingly. ...
More: The intelligent KG Mode sensor weighs the laundry and adjusts the cycle time, water and electricity consumption to suit the size of the load. This gives you the optimum consumption even if you are only washing one shirt.
During the first minutes of the cycle, the "Kg MODE" indicator remain on while the intelligent sensor will weigh the laundry
• Through every wash phase "Kg MODE"
allows to monitor information on the wash
load in the drum and in the first minutes
of the wash it:
- adjusts the amount of water required;
- determines the length of the wash cycle;
- controls rinsing according to the type of
fabric selected to be washed it;
- adjusts the rhythm of drum rotation for
the type of fabric being washed;
- recognizes
the presence
of lather,
increasing, if necessary, the amount of
water during rinsing;
- adjusts the spin speed according to the
load, thus avoiding any imbalance.
Dec 25, 2017 | Hoover Washing Machines
I have a Whirlpool cabrio washer that displays LF when I try to start a wash load. The water comes into the tub but it doesn't fill. After some time, maybe 10 minutes, the washer stops and displays LF....
Aha the old LF : Captain we have a problem. What is it Spock? Computers cannot confirm water is filling, water level does not change. Spock you did pay the water bill this month? What could it be Spock? Captain the inlet screens appear to have contaminants. Suggest you jettison them. If that does not solve it see test #2b7fe528.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 15, 2010 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
LSE7806A stack: the wash fills to the water level/load size selected. it starts to agitate then stops and begins to fill with water again which causes overflow, help please
Your fill sensor is leaking and allowing air pressure from the clear tube to seep out. First make sure your clear tube from the tub to the water level valve is firmly connected. If it is then you may need to get a new water level adjuster switch.
Mar 09, 2010 | Maytag LSE7806A Top Load Stacked...
How do you set the Cabrio to wash a small load?
this one only has 1 setting on water level. same size uses same level
Feb 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
May 27, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Mar 29, 2009 | LG WM1814CW Front Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Overfilling Whirlpool cabrio washer
Great! It may be the water level control switch. So, where is it and how do you check it or fix it or replace it?
Jan 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
193 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
