Question about Vacuums
How often should I change a hoover empower filter?
  • Vandywife May 25, 2008
    How do I change the hepa media filter?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=545652
Generic problem for all Vacuums
How often should I change?
Posted by jdl185 on Apr 25, 2008
How often should I change a Hoover Empower filter?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Depending on what type of filter it is, the suggested change for a filter is every 6 months to one year if it is a cartridge filter or HEPA filter, if it is a filter that can be vacuumed off or it might be a washable filter – you can clean it that way until the filter starts to fall apart – then @ that time you would want to replace it @ that time. Please check with you local vac dealer. Filters
It's important to replace your vacuum filter or HEPA filter regularly to keep your Hoover vacuum working best. Not only will this increase the life of your vacuum, it will also keep unwanted dust, dirt and allergens out of the air. Keep your home Hoover clean with genuine Hoover filters.
So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 25, 2008
3 Suggested Answers
  • 175 Answers
SOURCE: hoover empower lost suction
This machine has quite a few airducts to it. You must have a clog up in there some where. Also, make sure that all the filters to this machine are clean. That will help with keeping the vacuum from getting clogged again.
Posted on Nov 20, 2009
Vac Belts
  • 701 Answers
SOURCE: how do I change the ******** belt in a Hoover
Here is a link where you can view the manual:
Hoover EmPower Manual and Belts
Posted on Dec 02, 2009
My hoover empower vacuum wont turn on
Buy a Dyson I love mine! Sorry for being smart.
Jun 06, 2012 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Hoover empower belt need replace
To gain access to the belt: remove 2 screws at the top rear cover, next remove 2 screws at the bottom front cover. This will allow the cover to be removed. Then remove 3 or 4 screws that hold the roller in place (from the top). you will be able to see the belt and replace it.
Apr 18, 2010 | Vacuums
Does not vacum
You may have a broken or stretched belt. The machine could also be clogged. Here is a link that will take you to a site that will show you how to open up your vacuum to look for clogs and to change belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 29, 2010 | Hoover U5262-900 / U5260-900 / U5266-900 /...
My vacuum doesn't seem to be picking up debris
That means that you need to replace the belt. Here is the belt you need and the manual:
Hoover EmPower Belt and Manual
Jan 08, 2010 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Need to know how to replace belt on a hoover empower model # U5262-910
Here is a link to the belt you need and to a manual you can view with instructions:
Hoover Empower Belt and Manual
Nov 28, 2009 | Vacuums
How do you change a burnt belt for hoover u5269
If you go to this link you will find the belt you are looking for and you can also view the manual, which has step by step instructions on how to change the belt. Good luck!
Hoover EmPower U5269910 Belt and Manual
Oct 26, 2009 | Hoover U5269910 Bagless Upright Vacuum
Hoover empower lost suction
The first thing you need to do is remove the debris bin in the front. Turn on the vacuum and feel if there is any suction at the bottom of that compartment. If not then your problem is not a simple blockage and you can stop reading this right now, if you do feel good suction, you're in luck.
The problem is almost assuredly a blockage of some sort. The Hoover Empower's greatest feature is its simplicity of design which is basically a 12 amp motor creating a powerful suction over a very short path as vacuum cleaners go.
While you still have the debris container out of the machine, disconnect the accessory hose from its mount on the right (or "passenger") side of the machine and blow through it. You should plainly feel your own breath coming out of the rectangular slot in the area behind where the debris container mounts.
If you don't feel it, or if it is not strong, well there's your problem. You will need a Torx driver set to remove the 13 screws that hold the back of the vacuum cleaner on and the accessories hose in. Unless you are a total tool geek, you probably won't have anything like this around but you can pick up a set of Torx head screw drivers at any decent hardware store. The look like an Allen wrench set but the ends are different. Look at the screw heads and you'll see what I'm talking about.
Once you remove the screws, the rest of the job is a piece of cake. Brush out or wipe down the air channel and clear the accessory hose, put the rascal back together and buy yourself something nice with the 70 or 80 dollars you would have been charged to do the same work by someone else.
Gregory Glaser
Jun 20, 2009 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Cleaning my bagless vacuum
Hi Anne,
It does not say to get the filter wet but;;;;;;;;;;;;;;;;; I have had mine for 2 years. When I do a thourgh cleaning of the filter. I actually fill the inside of the filter up with water then hose the outside and let air dry. Another great thing to do is always have 2 filters. Let the one dry out and pop in a new one.
Good luck...
I have only had 2 filters.. and they clean out great with water..
Deb
Nov 17, 2008 | Hoover U6630-900 WindTunnel Bagless...
Have the empower upright cleaner. belt broke. can not find part #36528-040belt. can find a lot of hoover belts but not this #.Is there another hoover belt that will work on this vac?
No. if the wrong belt you will have problems. This is a common belt for Hoover, it used to be 36528027, but the number changed to the 36528040, also 40201190 is the newest number for this belt. Most repair vacuum repair shops should have this belt. You order it online at http://vacuumsuperstore.com/hoover_belts.html
Jul 13, 2008 | Vacuums
Vacuums Logo
326 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
