Question about Sharp AR-C260M All-In-One Printer
H5-01 Error, I need to clear this. How do I enter tech mode, I know the sequence is P# - * - C - * - 14 - start - execute. Its a sharp AR C 260
    Scholar:
  • Sharp Expert
  • 120 Answers
Did you open the left door and clean all the paper out of your fuser and exit area? If you cleared paper and code and get it again either your fuser needs a rebuild or your transfer belt if not moving paper through fast enough. H5-01 means five consecutive attemps to send paper through the fuser have failed.
Posted on Feb 09, 2011
I HAVE COPY MACHINE SHARP AR-5320E DISPLAY ERRO H2 AND NO FUNCTION PLEASE I WANT TO KNOW WHATS PROBLEM AND HOW CAN I REST CODE 14
You have a heat issue. Go into service mode select code reset 14 and execute. Turn power off and on. Now if you don't know how to enter service mode. You need a qualified tech. You tap version twice that will give another screen select sim 14 and execute.
Nov 19, 2014 | Sharp Office Equipment & Supplies
Blinking a printer screen number h then 4
press on the keypad, # * C * the machine will enter a diagnostic mode. Then enter 14 as if to make 14 copies. You may then have to press 1 and execute the program. But that will clear the H4 code 99 percent of the time. Once you enter 14, just press start and follow the directions on the screen. An H4 means the machine was just slow to warm up. It can be a fuser error, but there actually being a problem is extremely rare. Performing a clear 14 will almost always clear that. It may also be P * C * to enter diagnostics.
Feb 22, 2011 | Sharp AR-M205 Copier
Error code h4-21 in sharp copier ar237
That is a underheat condition. Should be able to clear it easily.
On the keypad/consol. Press in order # * C * ... sometimes its P * C *.
The machine will enter diagnostics or what is known as Sim mode.
Enter the number 14 like you were going to make 14 copies. Press start.
I believe on the 237 you will have to then enter 1 then execute or press start.
But that code is cleared probably 99 percent of the time with this procedure.
Let me know please.
But it just warmed up a little slow. Common fault.
Nov 11, 2010 | Sharp AR-M237 Digital Copier
Is there a reset code for a Sharp AR-507 copier, error H2-00?
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
May 04, 2010 | Sharp AR-507 Copier
Unable to enter program mode for Sharp AR-C260M Copier / Printer
Solved the problem by switch on press #P Then * then C then *  then 14  This will then ask if to execute the action to clear the service code H5-01.
Will need to ensure that the fuser unit is not causing a blockage on the feed out path as this code is caused by 5 errors / misfeeds in the Fuser unit.
Nov 13, 2009 | Sharp AR-C260M All-In-One Printer
AR BC320 H5-01 error Need to know how to clear it
# * C * in fast sequence. Then enter simulation 14 and press start button. Hit yes to confirm and then the copier will reboot.
Sep 30, 2009 | Sharp AR-BC320 All-In-One Led Printer
How can I get the error codes of my Sharp AR-507 and how to clear
Press the "P" key, the "Interupt" key, the "C" key then the "Interupt" key.
Once you enter the Simulation Mode, then "2,2, start (Print Key) will show the jam, service counters, and 2,4 start (Print Key)"will allow you to clear the counters.
To clear certain codes, once you enter the Simulation Mode, then enter "13 or 14 or 15 or 15 then start". Depending on the code will depend on which "number" you need to execute. (It doesn't hurt to do all the numbers."
Aug 08, 2009 | Sharp AR-507 Copier
How do i clear a F9-00 code for the sharp ar-bc320 copier?
Put the machine in test mode with the following key sequence:
P - * - C - *
then, 14-Start ... Execute ... Yes
CA to reboot the machine. For good measure, shut the power off, wait, and turn it on.
PS. - Get your copier on its' own outlet and share it with Nothing!!
Jun 30, 2009 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR 5320 error h200
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Mar 17, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-C260M All-In-One Printer Logo
244 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
