Question about Brother ML-100 Typewriter
I forget how to install a typewriter ribbon and correction tape, Brother typewriter and its only 25 years old! but I;m 86 so we are about even and I lost my instruction manual.
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support, poke around there an you will find a downloadable manual.
DickyO
Posted on Aug 16, 2010
Typewriter does not correct
There is a cam cluster under the ribbon plate that has to move over when you hit the correction key this lifts the correction tape, make sure the lift is not working and that the correction tape is old, and just does not lift off, have seen that...
Mar 21, 2014 | Brother ML-100 Typewriter
Correctable Ribbon not working. Even tried putting new one in
If the correction is lifting and being struck by the hammer the correction tape may be on wrong, the dull side must face the ribbon. The other easy possibility is that the ribbon is very old or non correctable. It should have a yellow or orange knob not red or blue.
DickyO
Mar 26, 2011 | Brother SX-4000 Typewriter
Just recently, our typewriter ribbon ran out and we ordered a new. It arrived and it works fine. However, the correction tape that we already had installed no longer "corrects." It rotates...
The ribbon you got is either very old or it is a non correctable one. The knob should be yellow or orange. The other possibility is that the nlift off is installed wrong the dull side should be towards the paper.
DickyO
Mar 16, 2011 | Brother SX-4000 Typewriter
The correction tap will not pick up all ink?
When the correction dosen't work the ribbon and or the correction tape are old. Put a fresh ribbon and correction tape on. Not one that has been sitting on the shelf for years.
DickyO
Nov 11, 2010 | Brother ML-100 Typewriter
Old typewriter Brother DELUXE 800 : ribbon reference ?
This is what you are looking for:
Brother Typewriter Ribbon spool black and red SC-20BR-BRO Compatible
The typewriter ribbons for use in Brother manual typewriters are usually all the same. What matters is the size (diameter and hight) of the spools.They differed only in that they were available in different colours (usually black or black and red) and in different materials: some ribbons were made of nylon (cheaper) and other made of silk (more expensive and higher quality) .
Maybe some old and good stationer's (papeterie) still carries them or has some in stock.
Or else you may want to contact the customer support service of Brother, in France, for advice on where to find them in your Country.
Sep 07, 2009 | Brother Office Equipment & Supplies
How to install correction tape in the GX-6500 Typewriter?
Move carrier to middle with spacebar.
Open lid, remove black ribbon and old correction tape.
Gently pull new tape apart a few inches. attach take-up spool (empty one) to right post.
Pass through right ribbon guide, sticky side faces platen!
Unspool carefully thread through left ribbon guide.
Attach feeder spool to the left post.
Turn the right spool to tighten.
GL
Jul 04, 2009 | Brother Office Equipment & Supplies
Replaced Typewriter Ribbon & Now Correction Tape doesn't work
Is the ribbon that you installed a correctable one? It should have a yellow or orange knob to turn it. If that knob is blue, you installed a multistrike or non-correctable ribbon.
The only other thing is you have the correction tape in backwards
Jan 12, 2009 | Brother SX-4000 Typewriter
Installing ribbon for an old portable Brother typewriter
Make sure the ribbon is on in the right direction being pulled not pushed off the spool
Dec 27, 2008 | Olivetti Lettera 25 Typewriter
Brother ML100 Lift-Off Correction Tape won't lift off
Correction tapes DO have a shelf life, Also make sure the ribbon is moving and very important and this may sound dumb, but I have seen it that the ribbon is not a correction ribon. Are the spool turns orange or yellow? should be. Blue is multistrike and will not correct. Don't know the shelf life of ribbons but they do loose the ability to correct.....Good luck try new supplies..
Jun 30, 2008 | Brother ML-100 Typewriter
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Brother ML-100 Typewriter Logo
211 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
