Www.pdfee.com/hyundai-accent-owners-manual.html
go to this site it will show you all you need to know
SOURCE: hyundai accent, location of fuel cut off
hi from uk location of fuel safety shut off valve/switch on uk r/h drive accents is on the engine bay bulkhead in front of drivers side it is a square box with red rubber top press button may be on opposite side on l/h drives ? if activated? just press button till click ? to reset these normally only cut off on impact ? to stop elec fuel pump continuing delivering if involved in an R.T.A fire prevention
SOURCE: changing timing belt on 2004 hyundai accent
Sign up for an account on hmaservice.com. Once you do so, log in and click on "Shop". You can then enter your year/make/model and you will find the info under, engine mech. system>timing system>timing belt>repair procedures. Very detailed, and best of all, FREE.
SOURCE: 2005 Hyundai accent overheating, radiator
A car can overheat for a lot of reasons.First make sure this is the problem by checking the radiator hose or water level. Open the radiator cap when the car is cold, crank it, and then watch the water level. If it drops when the car warms up this is not the problem.
The tools you will need will depend on what you have to take off to get to it. If you can access the thermostat you should only need a ratchet or wrench to remove it and something to scrape off old gasket with.
Location:The thermostat should be inside the thermostat housing on the motor. Follow your top radiator hose to the place where it goes into the motor. There should be a sort of dome shaped housing there with probably a bolt on either side of it.The thermostat is inside that.
This is a reasonably easy job, but shouldn't be done carelessly. It's also kind of messy.
When the car is cold remove the bolts from the housing with a ratchet. Lots of coolant and water will drain out. But the thermostat will be visible.Pay attention to which side of the thermostat is up.It should just lift up. Remove all the old gasket from around the area and clean it up well. Replace the thermostat and gasket then the bolts. Be very careful not to over tighten the bolts or the housing will be ruined.
SOURCE: Location of Fuel Filter 2004
A lot of parts store have manuals that you can buy or just look up what you want to know and leave it there.
SOURCE: trying to find the fuel filter in a 2006 Hyundai Accent
YEP! It's in the fuel tank at the bottom of the fuel pump... it's called a 'SOCK.'
