Solid black line runs down right margin of sent and copy pages...incoming faxes have no image issues???
  • 2,272 Answers
Very correct.The incoming pages will not have this issues.But when you send or copy pages at that time it get scanned from your scanner.The problem is either a minute dust on the scanner glass or the dust is got stuck up on the rollers which pull the papers.In some cases the dust gets collected inside the scanner glass.So it has to be cleaned from inner side.Take a torch and see it clearly where the dust is got stuck-up in.In some cases the scanner board the circuit board is got faulty.There is a minute fault on the board so at that point it leaves a gap on the paper.If the scanner checks out ok.Then its a printing cartridge problem in the fax machine.But i dont think that its the printing cartridge problem.Because if its cartridge problem then ,this problem should be on incoming pages too.And you mentioned that this problem is only seen on copy and sending pages.So its the dust on scanner glass internally or externally or the scanner board having internal short.Clean the scan glass properly and check again. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 03, 2010
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Solid black line appearing on right hand margin approx 1.8cms wide , how can i sort this please
please specify model no. of the machine & black line comes when u receive faxes or when u copy ? please let me know then i'll be able to provide solution. Thanks
Aug 24, 2009 | Brother Office Equipment & Supplies
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
BLACK LINE 1" THICK ON FAX COPY BEING SENT OUT
I bet your incoming pages are clean right? The Laser is not used for outgoing faxes.
Lift up your document feeder and clean the scanner glass that the documents are scanned across
Feb 24, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Incoming fax shows one half of the page
The Thermal printhead is most likely burned out on one side and will need replaced. It could also be the printhead connector has worked loose and is only making partial contact. Remove the connector and reinstall. If that doesn't solve the problem then it would be cheaper to purchase another fax.
Jan 22, 2009 | Sharp UX 108 Roll paper Thermal Fax
Solid Line on left Margin after Copy/Scan
When I Copy or Scan with my HP LaserJet 3050, a solid black line appears on the left margin of the page. . Can you suggest any solution to the problem. .
Oct 29, 2008 | HP LaserJet 3050 All-In-One Printer
Black line down right margin
Have you tried a new toner and drum unit? if not please do so. If that doesn't work then it is a scanner lamp failure and will need replacing.
You can fix it but trying to obtain this part for such an old machine will be hard. Don't know the part number sorry.
Thanks J
Jan 30, 2008 | Brother MFC 8500 All-In-One Laser Printer
Canon Pixma MP780 Fax Problem (horizontal line)
Solution is here: http://www.fixya.com/support/t136826-printer_problem
Mar 05, 2007 | Canon PIXMA MP780 All-In-One InkJet...
15 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
