Question about Cobra Digital DCA1030 Digital Camera
WHEN I TURN ON THE CAMERA AND TRY TO TAKE A PICTURE IT SAYS CARD LOCKED? I CANNOT FIND MY MANUAL RIGHT NOW AND THIS IS THE FIRST TIME I HAVE SEEN THIS!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cobra Digital Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Aug 03, 2010
When i try to take a picture it says card locked
Hi Tony,
Turn the camera off and remove the SD card.Some of the SD cards do have a small slide lock on the side.Slide it to open and then re-insert into the camera.Turn the camera on and try to take a picture now.
Hope this helps.Thanks!
Dec 16, 2011 | Samsung Cameras
Every time i try to take a picture "card locked
If that doesn't work, try another card.
Jan 03, 2011 | Samsung Digimax S500 Digital Camera
I have a Polaroid a330 and just bought a 2GB sd card. The manual says to format a card before using and gives instructions. However, when I insert the card and turn on the camera, the screen shows "card...
first try to see if the card is not locked from the side ..It has a little button that locks it ...after that insert the card into a computer with a card reader ..and format it in Fat mode...by opening my computer folder...right click on the removable storage device ...and choose format ...when it opens choose Fat ..and quick format ..than OK ..this will format it for the first time ..and after that isert it in the camera and see if it is seen ..
if the format card is not available now..(to format it in the camera again and be sure it is the right way and make the folders fro storage ) ..
goto storage feature in the main menu ..and choose to store in teh card ..in tis moment will prompt you to format ...or ..just choose a picture from the camera memory in the view mode..and options ..and try to move it in the card ..if it is not proper formatted will ask you to format it ..and give you the possibility to make it right the way by asking you if you want to format it now...choose ok..and that's all..But I suspect that if you unlock it ..and format it in a computer will work like a charm ...
May 30, 2010 | Polaroid a330 Digital Camera
Card locked please help
There are two reasons for card locked problem Canon PowerShot A400.
One is card locked while camera opening. The answer for this is explained in below figure.
34a2e3d.jpg The other one is dealing with card itself. The below picture shows that.
68ed342.jpg You may need the user manual for other problems.
This is User Manual of Canon PowerShot A400
If you find this helpful please vote.
Mar 04, 2010 | Canon PowerShot A400 Digital Camera
Unlock card on digital camera
I JUST HAD THE SAME PROBLEM WITH MY CARD SAYING ITS LOCKED.....TAKE YOUR CARD OUT OF YOUR CAMERA AND TURN IT WHERE THE LABEL IS FACING YOU AND ON THE LEFT SIDE IS A SMALL TAB THAT IS COLORED DIFFERENTLY THEN YOUR CARD....SLIDE IT UP TO WHERE ITS NOT ON THE LOCKED SIDE....
May 03, 2009 | Polaroid I533P Digital Camera
CARD LOCKED
There should be a small toggle along the end side (it is tiny and easily missed, but it is there, I just checked my memory card / mine is 4GB SD card from Sony) that you can swtich to unlock and your images may come back that way.
Look for it this way, hold the card face down it should be on the back edge where you use your thumb or finger to push it into the slot on your camera.
Mar 03, 2009 | Canon PowerShot A540 Digital Camera
When viewing picture from camera question mark appear no picture
try formatting ur memory card sometimes after adding deleting pics it gets corrupted or becomes in such a format that is hard for a camera to show u , becoz sometimes u use ur memory card on card readers and then edit them there so they are unable to be read in camera try formatting the card temme if it helps
Feb 20, 2009 | Canon PowerShot A700 Digital Camera
Turned camera on but it won't respond in anyway...
I've seen a couple of these now that describe similar problems with the D90. I haven't seen anything from Nikon, though. Common issues like that are normally fixed through firmware updates, but there are none out for the D90. Given that it's still under warrenty, you should take it to a local Nikon dealer and let them help you.
Manual and online (you probably know) are not too helpful on problems like this. They just tell you to put in a new or fresh charged battery.
You might try formatting the card in a PC and seeing if that clears up problems.
I've had a D70 for years and I had no problems like that at all, but I always format cards when I put them in camera, and I format on the PC every so often.
Jan 17, 2009 | Nikon D90 Body Only Digital Camera
Card is locked
Try removing the SD card from the camera and slide the lock switch on the side of the card to the unlock position.
Oct 22, 2008 | Canon PowerShot A400 Digital Camera
Optio 60 Card Locked
if it says card locked. take out your memmry card on the side of it should be a white little strip you probably swtiched it to locked! you can unlock it by clicking it up!!!
Jun 23, 2007 | Pentax Optio 60 Digital Camera
Cobra Digital DCA1030 Digital Camera Logo
55 people viewed this question
Top Cobra Digital Cameras Experts
Daniel Dollive
Daniel Dollive
Nobody
Nobody
Level 1 Expert
Tony Parsons
Tony Parsons
Are you a Cobra Digital Camera Expert? Answer questions, earn points and help others
