Question about Whirlpool Dryers
I don't know anything about dryers so please bear with me. My dryer drum turns, fan blows, but wont heat. replaced heating element. Still no heat. Has 124 volts on both prongs of element. What should i do? Whirlpool mod. LER 7646EQ2. Thanks Jerry
Have you tried flipping the breakers @ your electrical box? Mine will do that at time when one breaker has tripped. It will have enough juice to run it but not heat it. IF that doesn't work there may be a broken wire to the heating element or possibly even a faulty heating element. I'd try the breakers first though.(Im not a professional I've just been a single mom for 18 years and have found myself working on all sorts of things and gaining knowledge from hands on experience) Hope it helps & works.
Posted on Aug 03, 2010
Where are fuses located in Frigidaire front loading dryer?
No fuses. Probably Heating element or one of the thermal switches. Electric dryer I am assuming
May 24, 2015 | Frigidaire Dryers
Continues to blow the high temp stat. I clean the blower and replaced the venting. I also replaced the heating coil the dryer heats up for a load and then it stopss heating. I test the high temp stat
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Feb 17, 2015 | Dryers
Lg dryer fuse keeps blowing but the heating element and thermostat all have continuity
I have been using an LG domestic dryer in a commercial application (motel) for 5 years and the only problem has been a lint build up inside the dryer because of an improper vent installation. The problem is likely in the dryer drum motor, it runs for a short time heats up because of bad motor bearings, improper motor cooling or bad drum bearings (motor drives the drum) increased heat = increased amperage= blown fuse. Motor should go out on overload but it may blow a fuse first. Is the fuse in the electrical panel or in the dryer? Try turning the dryer drum by hand and check for resistance, there shouldn't be much. The motor needs to cool so pull the dryer panels apart and vacuum the inside first and make sure the motor and interior has been thoroughly cleaned. Try this for a quick fix first.
Jan 31, 2015 | LG DLE3777 Electric Dryer
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
No heat , drum turns and wont shut off
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Hi, On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
May 05, 2010 | Whirlpool LER4634J Electric Dryer
Ok got a GE DVL223EB1WW Insufficent Heat
Yes think so , what should happen is element heats up controlled by fan blowing cold air across it this then heats to whatever thermostat is set to switch at, which in turn controls heat level..Air is then exausted via hose to waste unless its a condenser drier which then turns the steam back to water / which is collected in a waste condesate drum..hope this is helpful...
Nov 19, 2009 | GE DVL223EBWW Electric Dryer
My creda t622cw dryer had no heat so I have replaced the thermostats, but when I tried it there is heat but the heating element gets very hot and turns red, is this normal or do I need to replace this as...
The fact that the element gets red hot, shows that there is nothing wrong with the element, it will get red, more so if you tried it without a cover or panel over it, as normally the fan blows the air over the element, make sure the drive belt is o/k, and the drum is turning.
Please rate my solution.
Thanks.
Nov 13, 2009 | Frigidaire Electric Dryer
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
GE Profile Harmony Dryer DPGT750EC Drum won't turn & no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Thermal fuse
Wiring
Jul 04, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryer wont turn on
This is usually a symptom of a thermal fuse that has blown. A blown thermal fuse is a symptom of other problems (usually). That is to say that they generally blow for a reason. The most common cause is a dirty dryer and/or clogged vent duct. If it's been a while since you've cleaned your dryer and/or the vent duct, you might want to do so BEFORE you replace a thermal fuse. Or, the problem will persist. If your heating element is in the rear of the dryer, the thermal fuse will be located on the blower fan housing on the left hand side of the dryer. It is white in color. If the heating element is located inside the dryer under the drum, the thermal fuse will be located on the blower fan housing right under the drum in the front of the dryer. The fuse should read a short. If it does not, you need to replace it. It is not resettable. Let me know if you have any further questions. I hope this helps you.
Sep 14, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
