Question about Toshiba Computers & Internet
My toshiba satellite l355 won't show the video through an epson multimedia projector. What is wrong?
    Sergeant:
  • 305 Answers
Occasionally this happens if you have had the computer hooked to a TV. I have had to disable the existing icon in Catalyst Control, and reboot. It should then find the projector, unless you have it set to manually find. There are several ways you can enable the projector, but they all boil down to the computer has to find the projector connection before anything else will happen. If it thinks there is still a tv hooked up, it will not work with the projector.
Posted on Aug 03, 2010
Toshiba satellite l355
If it works on batter for a while, it is not either the motherboard or the cpu
May 22, 2013 | Toshiba Satellite L355-S7831 laptop ac...
Toshiba satellite won't go on
Hello. It sounds like either...
1. Your power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
If you are going to buy a new toshiba ac adapter, you may consider the following toshiba l355 charger:
Replacement Toshiba Satellite L355 AC Adapter 90Watt 19V 4.74A
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Dec 01, 2012 | Toshiba Satellite L355-S7811 Notebook
I have a Toshiba L355 s7915 laptop, the screen lights up but no picture, can connect external monitor and get picture and everything is fine on the external monitor. What could be wrong?
the connection between the screen and the video card is bad. so if your laptop is under warranty take it back to ever where u bought it from and ask them to replace it.
Jun 28, 2011 | Toshiba Satellite L355-S7915 Notebook
Our epson lcd projector is not working with our Toshiba computer. It had been working but all of a sudden is not. The projector works with other computers hooked up to it. What should we look for as far as...
connect the toshiba to a monitor and see if the video is coming out.
If not then use the PC function keys to switch the video to the external vga output connector.
Mar 14, 2011 | Epson Office Equipment & Supplies
Can i replace a toshiba l355-s7901 motherboard with a toshiba l355-s7915 motherboard
Going out on a limb here, but I'm going to state yes, except the s7901 has hot keys in the center strip under the LCD screen. Above the Keyboard, where the Power On button is located. The s7915 doesn't.
Toshiba Satellite l355-s7901,
http://www.notebookcheck.net/Toshiba-Satellite-L355D-S7901.14988.0.html
You can click on the photos towards the bottom to enlarge.
Toshiba Satellite l355-s7915,
http://www.notebookcheck.net/Toshiba-Satellite-L355-S7915.19879.0.html
Same with the photos at the bottom.
I know this doesn't seem like a very professional answer/solution, but in viewing both of the laptops the ports, (USB, DC Power Jack, etc.), and the peripherals, (DVD optical drive, add-in card drive, etc.), seem to be in the same place.
Viewing a Service Manual for the Toshiba Satellite l350 series of Notebook PC's, shows removal procedures to be the same across the board, no matter what model deviation it is.
As long as it's one of the Satellite l350 series.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the second Satellite file header. The one that starts with Satellite A10.
Now go down to the second line, and then go across to L350, and click on it.
This is a PDF file. May take up to 30 seconds before you see the first page, and additional time to fully download.
Do I know for a fact they will interchange? No, I do not.
I'm willing to bet strongly that they will.
Nov 20, 2010 | Toshiba Computers & Internet
Powerpoint video won't play on screen
you can try changing your overlay settings. works with some formats. or you could use the projector as main display (toggle through fn+LCD/CRT)
Feb 10, 2009 | Epson PowerLite 50c Multimedia Projector
EPSON EMP-S4 PROJECTOR
switch your video source first and then the projector second-confirm that you select video input from menu or from your input button-confirm that your video cable is good ,change it with another good one to confirm that there is no problem in cable.
Feb 12, 2008 | Epson EMP-S3 Multimedia Projector
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
