Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
I have a B & S vanguard 20 H.P. vert. shaft, 8 years old on Simplicty tractor. Keeps fouling plugs. Clean or replace plugs and it runs fine for about 1/2 an hour then starts to miss, blacksmoke, and backfire. Checked everything. Changed air filter, fuel filter. Compression is 150 psi on both cylinders
    Scholar:
  • 66 Answers
Anti-foul plug adapters might be a temporary solution (treats the symptom and not the cause).
Personally, I would take it to a good, reputable, small engine repair shop that has verifiable references, and have them repair it.
Posted on Aug 03, 2010
Simplicity landlord dlx tractor mower
Try looking at the Governor on the engine. You can usually adjust this out at the Gov arm by loosening and tightening back when smooth. Could also still be dirt in the jets. Make sure all the small holes on he carb are clear and check the float height too.
May 02, 2014 | Garden
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
After 8 years in storage my 1982 Craftsman LTV 11 tractor will not start. (B&S vert shaft eng.) It would crank when jumping the solenoid, but not start even with switch in run position. I installed...
Not sure what all you have done. Most problems are in the carb. Did you replace with fresh gas? clean the carb. check for spark and compression. use ether or starting fluid into the carb air intake.
Jul 24, 2017 | Garden
I am considering purchasing a used Exmark with a 23 HP Vanguard engine (~70 hours on the engine). I've not been too pleased with Briggs (have one on my John Deere garden tractor - hot natured and...
yep its a briggs and normaly there very good ploders
if your john deere spluters and back fires it needs a good looking at check the valves first,,,a hand full of bolts and the heads off and if your carfull you can still use the same head gasket again,,,also check the carb there very finiky and need to be kept clean the air filter is a joke,,,but clean it anyhow and they like new plugs,,,every ten years or so? iv worked on 100s of brigss and stratons/vanguard. there good engines but there ploders not sprinters there ok in a tractor but no good in a tank there to darn slow
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Tractor starts then stop running
It will either be the stator that needs changing or the carb needs to be pulled off and cleaned
Jul 01, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
493 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
Daryl Gleaton
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
